Yeah... getting the right engine for your purpose also makes a big difference. I drive about 5K miles a year so any engine swap is pretty much a no-go.
302 Economy Build
It wasn't specifically the emissions controls, it was the implementation. No computer controls for anything so timing and activation of the systems were pretty imprecise, usually involving mechanical thermal switches and vacuum delay valves and other nonsense. No way of monitoring or adjusting fuel mixtures or ignition timing to ensure efficient fuel burn. Also consider these things were added to engines designed long before any of that was a concern, so it was very much a compromise to make it all try and function. Electronic controls really did wonders for both performance and emissions, even when it was still attached to old design motors. It also just ran better, those early smog controls were pretty unreliable and got downright shitty to drive when they acted up.
Modern engines are designed around efficiency and emissions. Different combustion chamber shapes, cam profiles, etc to promote more complete burning. Cats flow better than they used to. Production cylinder heads now are just miles better than anything from the "old days".
The trick with small displacement, forced induction is that its kind of a variable displacement system. Pump air into an engine and it acts like its got more displacement than it really has. Cut the air down and you're back to what it really is. With variable vane turbos you get a big motor for acceleration and a little one for cruising. Power and economy in one box, though not really at the same time. Cylinder de-activation aims to get to the same place but you get a lot more parasitic loss with that. Even if its not being fired, just moving that piston up and down consumes an amount of power.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostIt wasn't specifically the emissions controls, it was the implementation. No computer controls for anything so timing and activation of the systems were pretty imprecise, usually involving mechanical thermal switches and vacuum delay valves and other nonsense. No way of monitoring or adjusting fuel mixtures or ignition timing to ensure efficient fuel burn. Also consider these things were added to engines designed long before any of that was a concern, so it was very much a compromise to make it all try and function. Electronic controls really did wonders for both performance and emissions, even when it was still attached to old design motors. It also just ran better, those early smog controls were pretty unreliable and got downright shitty to drive when they acted up...
My '89 K1500 sports one of those engines designed before those things were a concern. But like you said, it runs remarkably well with electronically controlled stuffs. The '79 G10 Sport Van I got going again? Whoo boy, the first thing I did was disable the EGR. Would have disabled the smog pump if it had one too, or any other non necessary device controlled by Rube Goldberg like devices. With the timing bumped up, it ran quite well for a smog era six.
For getting the job done or MPG, my concern is torque. Don't really care about horsepower, it's only a function of torque anyway. Years ago I had a 2.3 Quad powered '94 Grand AM. I loved that little POS, got 32+ MPG on the highway all week long. Don't know what the torque to displacement to weight ratio was on it, but it seemed optimal.1985 LTD Crown Victoria - SOLD
What I have read about the EGR system is that it actually provides a small increase in fuel efficiency along with a decrease in emissions. Basically it returns a portion of exhaust containing unburned fuel to the intake to ring out a bit more energy simultaneously making a cleaner exhaust.
The air pump I don't know if that is a net drain efficiency wise or how much drain it is vs. how much pollution it eliminates (ROI)03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Air pump is only for heating up the cats. So it's only really active for about 5-10 minutes. The rest of the time it's only drawing vacuum to assist with the cruise servo. I found that removing it gained about 0.5 to 1 mpg when I had the 88 MGM (Mad Marquis).
Most modern EGR systems are good for MPG, older systems not really.
New stuff changes ign timing depending on egr position, with the egr open, timing can be advanced more, and kinda has to be, as the exhaust gases ignite slower. Inert gases cool the ignition temps. Almost all newer systems also cool the recirculated gases, to lower cylinder temperatures even more.
EGR also reduces manifold vacuum slightly, which helps with cylinder fill a little bit. Of course diesels dont have vacuum, so it doesnt work. Diesels also produce soot and particle matter, which causes the intake & egr systems to clog up and fail. And thats why diesels are so often "deleted".
I'd wager that the EEC-IV doesn't change timing in egr open situations. Also I'd seriously question the overall effectivess of the CFI egr cooler.
Personally I can't say anything on the effects on EGR on my box, I have gone back and forth, but the overall running condition might ruin all of that.1985 Mercury Grand Marquis LS, "Maisa"
EEC-IV does lean out the fuel mix and bump the timing on the SEFI cars at least.
One big down side for how early EEC-IV does EGR monitoring is that it just uses a position sensor. It has no idea how much is actually flowing, so its just a guess based on whether it sees the valve open or not. Entirely possible for the passages to be clogged solid and allow no flow. Things get prone to detonation when that happens because the fuel and timing are set to expect exhaust gas.
EGR works on everything I own except the diesel. Can't say I've ever noticed an obvious difference in performance so long as the system worked right. When the control solenoid was flaky on the Towncar it went full open just off idle and caused an annoying hesitation but that went away when I replaced the bad part.86 Lincoln Town Car (Galactica).
I drove dad's T-Bird on a long highway run and nailed 30 mpg average over 200 miles on the trip computer. 24-26 is pretty standard for it. The aerodynamics and lighter weight certainly helped.
IIRC the E6SE heads were designed for high turbulence/swirl to aid in part throttle cruise efficiency?1990 Country Squire - weekend cruiser, next project
Originally posted by Tiggie View PostI drove dad's T-Bird on a long highway run and nailed 30 mpg average over 200 miles on the trip computer. 24-26 is pretty standard for it. The aerodynamics and lighter weight certainly helped.
IIRC the E6SE heads were designed for high turbulence/swirl to aid in part throttle cruise efficiency?1985 LTD Crown Victoria - SOLD
