Lincoln Mark VI interior into a Vic/Marq
    Thread title is self explanatory. Can fancy Mark VI interior be swapped in to a Vic or Marq?
    I would imagine so... sans the rear B/C pillars due to different windows and maybe the door cards wouldn't fit right. I know the seats will swap. I imagine the dash would swap too since the firewall is pretty much the same. But I think the interior side panels are different lengths and would have to be shaped.
      yeah, pretty much that ^ . carpet could be fit, but the rear footwell area would need a section removed in order to fit correctly. Beyond the seats though I don't think any of it is just a drop-in.
        If it's like Town Car you'll have to swap the Vic/GM side-mounted seat switches to the Mark VI seats.
          Mark VI and Towncar interiors are effectively identical other than the C pillar trim in the back. I have most of a Mark VI interior in my Towncar.
            For anyone curious, the door panels won't fit. Door handles sit more forward on a Lincoln, the actual inner door structure is also different and many of the holes for push pins are in different places. It can be made to fit but will require custom fabbing.
