Side Marker Lights
    Side Marker Lights
    What is the function of these lights? I just replaced the bulbs on the driver side and when I went to test all the lights; I can't get these to light up; on either side. Are they on their own circuit?
ID:	1305929 Click image for larger version
    Cornering lamps; same thing as the "ditch lights" on a box. They illuminate solid and throw white light down and to the side while the turn signal for the same side is on.
    Current driver: wagon
      Yah; I tested both sides with the blinkers and they don't light up; just the amber bulbs blink.
        Did you have the headlights turned on when you tried it? AFAIR they only operate if the headlights are on.
          +1 only when headlights are on.
            OT-ish but the lineage/evolution of that feature is neat trivia. To me anyway.
            Boxes pre-90 require key-on, turn signal on, no requirement for headlights. The turn signal circuit powers one of those weird thermal relays that acts as a delay timer, and relays power to the cornering lamp.
            Boxes 90-91 (and probably aeros to 94, pre-LCM) do not require key-on, but do require headlights on. This has the effect of you being able to use the cornering lamps as exit/courtesy lighting in combination with autolamps.
            I don't know if the LCM cars require the key on, I don't remember from my 97. I do however remember that some LCMs in specific years have an extra connector related to cornering lamps which other years don't have.
              You people are genius'!!! I put the headlights on yesterday and used the blinkers and they came on. Thank you
