Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Cadillac Horn Mod
    Dec 2019
    Fort Irwin, CA
    330
    Default Cadillac Horn Mod
    I've procured a set of four-note Delco-Remy horns from the junkyard and would like to swap them into the Lincoln. Mounting issues aside, my plan is to wire them up in sequence using a stock harness from an Eldorado and run that wire back to the horn relay. Someone elsewhere on the internet felt that these horns will draw maybe 5A each. I believe the stock horn relay is good for 20A and the horns and cigar lighters together are on a 20A fuse.
    Should I be upgrading the relay or putting these horns on a larger or separate fuse? Or will the stock wiring support them?
    Nov 2014
    Evans, GA
    1,954
    While not a Box, I fitted the same setup of horns on a '99 CV and used the stock wiring, save for where I removed the connector and spliced a daisy chain of spade connectors together to send power to the horns. Despite the horns also just using a chassis ground, I also daisy chained a ground wire linking them together back to the factory ground, just in-case the support I attached them to wasn't 100%.
    Noticed no issues or blown fuses, so I'd say run with what you have.
    41,311
    do both of the horns live in the same fender on a Towncar or is it one in each side? I honestly don't remember.
    23,084
    I'd trigger a relay with the stock horn circuit to drive all of that with a dedicated line from the battery just to cover it. Also... 20A should be peak for 4 horns. I think typical is about 1-3A per horn. But 10A fuse per pair of horns should be about right for covering the electrical requirements.
    Sep 2014
    Warren, MI
    6,790
    One in each fender.
    For the longest time, even when adjusted within resistance spec, both of my horns were pulling over 20A. Aside from the starter motor, I'm pretty sure the horns draw the most current. Perhaps only superseded by the blower motor.
    Dec 2019
    Fort Irwin, CA
    330
    I've given the wiring diagram a good deal of scrutiny tonight, and it looks like the stock wiring is very nearly a dedicated circuit just as it is. The only other thing on the same fuse is the dash cigar lighter. Used to light a cigar I could see it drawing some good current, but as a USB/phone charger it's probably not putting much stress on the fuse at all. From the fuse a wire runs out to the horn relay, which can also draw horn power from the anti-theft system, and then out to the separate harness in front of the header panel. There's a connector to this harness right beside the relay. This would probably be the connector to re-pin with the Cadillac horn harness.
    If the four-note horns draw no more than 20A, the stock wiring and fuse should be sufficient. If they draw more, then I think you'd not only need to run a separate line from the battery, but you'd also need to beef up the wiring to and from the anti-theft module, which has its own set of fuses.
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,674
    Just fyi, cadillac uses a 20amp horn relay as well, I wouldn't sweat it.
    Dec 2019
    Fort Irwin, CA
    330
    Well that seems pretty definitive then. Honestly not as much work as I expected it to be. Finding the right spot to mount the horns is maybe the hardest part of the operation.
    Ontario, Canada
    3,674
    Close to the stock location works real good. When I added horns to my truck I put them down low up front in the engine compartment and the sheet metal has the added bonus of acting like a speaker, definately adds to the overall tone vs just being mounted ahead of the radiator, and it keeps them out of the water spray.
    Member TheEnglishChap's Avatar
    Jun 2022
    Lakebay, WA
    30
    My OEM horns are not working on my 87 CP, but there is power running to them (can hear the relay clicking away).
    Of course, the locations in the fender is not the easiest to get to - how would you do this?
    Not being electrical-minded, how difficult is it to get the A-C-D-F horns installed? If someone has set of instructions - that would be great!!
    Thanks!!
    23,084
    The horns have a single wire going to them and are grounded through the case/bracket. Each side of the car you just need to unbolt the item in the way and move it enough to get at the horn. Battery needs to be removed on the passenger side to get at that horn and the coolant/washer tank unbolted from the car and just moved over a bit to give enough access for the driver side. Make sure each one is bolted down properly and the contact points are not corroded. Also, pull the connector off the horn and verify power at the horn. If no power at the horn, the relay may be bad. If you do have power, try cleaning contact points for the bracket and plugging the horn back in with everything bolted down snug and try again. If still nothing, then yeah... new horns needed. You can replace with like (dual tone - one tone per side) or modify to your desired pedestrian scaring levels.
    Jun 2022
    Lakebay, WA
    30
    Thank you sly!
    "... desired pedestrian scaring levels." - funniest thing I have read!
    Jun 2022
    Lakebay, WA
    30
    The Declo-Remy four note horns arrived this morning - yay!
    Now for the part I am going to hate... wiring them in.
    1. Is there a particular order they need to be mounted?
    2. I was planning on mounting them behind the grill in a row. Can I run LH & RH original fender connectors to each pair?
    3. Any other useful tips or advice would be most welcome!
    23,084
    1: No.
    2: Yes.
    3: just use 1/4 spade connectors to connect to the original connectors and wrap with heat shrink or electrical tape. If the kit requires grounds, just run the grounds to the brackets and bolt them to something metal.
    Donating Member massacre's Avatar
    Oct 2011
    USA
    593
    Great advice here ^^^
    Fastest Boxes In South Jersey 86VickyLX's Avatar
    Jan 2007
    Westmont, New Jersey
    10,427
    fun fact, 2 of the delco remy horns are the same tone as the stock horns. So realistically, you only need to mount 2 of them. I would strongly recommend upgrading the horn relay.
    Ontario, Canada
    3,674
    Quote Originally Posted by TheEnglishChap View Post
    I highly suggest mounting them in a more protected location. My '83 truck has (had) the factory horns behind the grille, they get water in them and that kills them. The stock horn location in the box is what I would call almost ideal, the fender acts as a speaker or sorts and adds some body to the sound. I moved my truck horns to the front fenders behind the headlights (one on each side) in the engine bay and it has a much better presence when you need to sound the horn, especially noticable when having to alert idiots trying to lane change into you as the horns now beside them instead of ahead of them. Forward alerting is not negatively affected either from my observation, that presence seems to be more pronounced in a wider path.
    Jun 2022
    Lakebay, WA
    30
    Electrics is my weakest point... so please excuse my lack of correct terminology...
    I believe my horn relay is on the driver's side, close-ish to the horn itself. It is below two larger ones - is this the relay I need to upgrade? If so, with what exactly.
    With thanks!
    23,084
    Yes, that's the one. If the wires are still in good shape, You can probably just leave it alone. If the insulation is shinking back and exposing wires, it should probably be replaced (harness and all) and might as well put a standard Bosch style relay (generic ones you can grab off the shelf in a parts store) in so you don't have to source the Ford specific ones. The circuit itself should handle the new horns. I think it's a 10A circuit. If the package says anything about how much current draw the horns have, compare that. If it's more than 10A, you'll need to run another relay. If it's less then or equal to 10A, you're fine. And this is the "peak" value if they have that listed.
    Jun 2022
    Lakebay, WA
    30
    Sadly Sly, there is no information on that. The fellow just sent them. I will figure out somehow to run a draw test on each horn to check this.
    If I was to end up getting a new relay, what exactly would I need. A quick look for (bosch) horn relay on napa and rockauto, but nothing matches.
    And of course there is nothing in the workshop manuals I have about the relays (or else I am not creative enough to work out under which section they would fall under.
    For the OEM horn testing in the book, the amperage should be 5.5A per horn. Does that mean the relay is higher than 10A?
