Results 1 to 15 of 15
Thread: 302 HO in an EFi MGM
    Member Tanner02480's Avatar
    Aug 2018
    Sherbrooke, QC
    57
    Default 302 HO in an EFi MGM
    Hi guys,
    My 88 MGM's engine must be replaced or rebuilted.
    I found a 94 mustang engine (302 HO)
    I'm wondering if I can install the EFi upper intake , sensor wiring... ont the HO engine and could work as is ?
    Is it possible to fit the Efi upper intake directly on the HO lowe intake without modification ?
    I know I have to change the firing order and I don't care about more hp, I just want my car live again.
    Thanks !
    1987 Colony Park LS wagon
    1988 Grand marquis LS sedan
    May 2017
    158
    The stock intake is diff from the HO and I think the 94/95 had that weird elbow. Probably gonna have to find a previous year intake or get one from an explorer
    May 2017
    158
    Honestly if you donít care about power then just slap the stock lower/upper intake and call it a day
    23,089
    The 94 mustang engine has a different firing order. So you will need to swap in the engine computer from a Mark VII as well. You can use Mustang ECMs but you will loose cruise control.
    Also, the HO intake should be reversable to point in the correct direction as well. But you will need to make custom brackets to get the throttle/TV cables to fit right.
    The easiest way would be to swap a lopo cam into the HO long block and swap all accessories, water pump included, onto the HO block and put the lopo intake on top (upper and lower sections). Then there's no wiring or ECM shenanigans to worry about. Still a PITA though.
    Dec 2021
    554
    Unless you REALLY want to do what you asked it would be much easier to find a competent re-builder for your current engine and call it a day!
    351W & F.A.S.T equipped
    Aug 2010
    Moore, SC
    536
    Slap the 94/95 HO engine in with YOUR upper plenum just like stock. Plug in a Mark VII ecu like Sly said and youíre ready to rock. Easy-peasy
    6,734
    This. If you don't want the extra horses from the HO. The lower intakes should be the same.
    You sure you don't want the extra horses? It's 75 more. That's a 50% increase over the 150 stock. You could leave the HO long block alone. I'd really consider it if you have the HO donor.
    May 2017
    158
    That was my bad, for whatever reason I was convinced it had the gt40 plenum design. I had seen someone on the pimpxs forum selling a standalone ecu for 500. Might be cheaper than a rebuild or tearing down the block and switching cams or trying to find a mustang ecm and harness. Also itís pretty much plug and play on our cars.
    Sep 2014
    Warren, MI
    6,790
    Quote Originally Posted by sick88tbird View Post
    Slap the 94/95 HO engine in with YOUR upper plenum just like stock. Plug in a Mark VII ecu like Sly said and you’re ready to rock. Easy-peasy
    This would work and would be easiest, but you'd be losing ponies as the upper plenum is only 40mm whereas the HO is 60, if I recall right. That's where more work comes in though, as you have to swap linkages from your TB to the HO TB and bore out the stock EGR spacer or get Lightning stuff. Something like that.
    May 2017
    158
    You can also put the stock egr and tb like I did when I did the gt40 swap. Still got more power than I did before.
    41,317
    50 vs 60mm on the throttle body. The 93- HO upper should be available, Mustang guys removed those things for years. Need the throttle body, a friend with a welder to swap the levers over, and someone with a lathe or a mill to bore out your existing EGR spacer to the proper size to marry it all together. That can come later, short term just stick the lopo upper on and roll with it.
    Aug 2010
    Moore, SC
    536
    Iíd be willing to bet that if you were a REAL miser, you could simply change the fuel injector wiring to match the HO firing order and it would *probably* still work without changing the ECU. Iíve had HOís run and idle fine of off the stock LOPO ECUís before(without changing any wiring), but didnít drive them so I canít speak to the drivability of doing that.
    41,317
    no. Do not fuck with the injector wiring under any circumstances ever. The fuel trims will be incorrect. Less harm from leaving it with the wrong firing order and 14# injectors than swapping bank to bank. The ECM knows that 1-4 is one bank and 5-8 is the other. Shuffling the wiring around puts 1, 2, 5, and 7 on one bank and 3,4,6,8 on the other. It will not be possible to lean out bank one or two without having it shift on both sides at the same time.
    This is a very well tread path at this point, and if its possible to fuck it up, I'd bet money someone has already done it. Handily the route that works is also the easiest, just plug the right ECM in.
    Nov 2020
    Olathe Kansas
    137
    Plus 19lb injectors
    1987 CV LX 5.0
    Aug 2010
    Moore, SC
    536
    Yeah, I didnít even think about that. Would be along the same lines as having the O2ís reading from the wrong side. Creates a runaway rich/lean condition as it continues to try to correct one bank or the other but canít. Sorry guys, screwed the pooch on that comment! Lol
