Results 1 to 17 of 17
Thread: Fuel pump
    Member 9t3lightning's Avatar
    Nov 2007
    East Norriton,PA
    198
    Default Fuel pump
    My 90 wagon has been sitting for 1.5 years went to start it and no fuel pump
    Hum when the key turned on.
    Swapped out the fuel pump relay and still nothing. So changed the pump
    And still nothing. Is there a fuse or fusible link I’m missing ?
    Dec 2021
    668
    Should be a fuse and also a fuel pump protection module (normally in a trunk but somewhere in the back of a wagon). Wagon "buffs" here can post where exactly it can be found. It cuts off the fuel pump in case of a rear end crash.
    Inside the drivers side panel near the tail lights.
    23,228
    The inertia switch (cuts out the fuel pump in case of a collision) in wagons is usually in the dead space behind the rear glove box. If resetting it doesn't help, try jumping the connector to bypass it. They can go bad.
    Dec 2021
    668
    Yep - Inertia Switch - the name did escape me!
    Nov 2007
    East Norriton,PA
    198
    I tried the inertia switch too,
    I’ll try jumping it out and see.
    But as for a fuse? None mentioned in the owners manual or electrical manual?
    Jul 2019
    Finland
    1,398
    Quote Originally Posted by 9t3lightning View Post
    Not sure if SEFI is the same as CFI, but my car has a fusible link where the fuel pump relay gets constant power from the starter relay stud.
    GMN Regular WagonMan's Avatar
    Bridgewater Ct.
    936
    Check for power at the fuel pump relay, its always hot without the key on. WagonMan
    89 Colony Park
    90 Colony Park
    70 HEMI Daytona Convertible
    Nov 2007
    East Norriton,PA
    198
    Ok
    So i can hear the pump coming on now
    Aftermarket pump isn’t as noisy as the factory one . But
    Still no start.
    Question on the pump
    Connections, could I have put the wires on backwards and the pump not pumping correctly ?
    I checked the shrader valve and it seeM to have some pressure .
    Sep 2014
    Warren, MI
    6,911
    What is "some pressure?" Perhaps you've got an ignition issue.
    Fastest Boxes In South Jersey 86VickyLX's Avatar
    Jan 2007
    Westmont, New Jersey
    10,434
    Ok
    Still no start.
    You absolutely could wire it backwards. It won't pump fuel up to the rail. Do you have a fuel pressure gauge?
    How old is the fuel filter?
    Nov 2007
    East Norriton,PA
    198
    I do have a pressure gauge will have to try that tomm
    The pump wasn’t marked so it was a 50/50 chance
    And it’s definitely a fuel issue since she fires right up on starting fluid
    Member TheEnglishChap's Avatar
    Jun 2022
    Lakebay, WA
    30
    I had a fuel issue too, so replaced the following in order:
    1. Fuel filter (under pax rear well);
    2. Fuel regulator (a total arse to get to!);
    3. Fuel pump.
    The pump was actually okay, turned out that little hose from the pump to the rail that had split in a few places.
    Nov 2007
    East Norriton,PA
    198
    Ok so changed the filter just
    To make sure and have 38 for fuel pressure at the schrader valve.
    And all she does is crank
    But if I squirt starting fluid in the throttle body she fires right up
    Wtf
    Dec 2021
    668
    Sounds like the fuel injectors may not be opening. Don't believe a '90 Wagon has a crankshaft or camshaft sensor so the injectors may not be getting power from the PCM. I would check for power at the injector connectors and take it from there. I'm sure someone will correct me if I am way off base.
    Nov 2007
    East Norriton,PA
    198
    Took a test light to the injectors
    They have power with the key on
    Like they should
    Dec 2021
    668
    Like they should
    Likely so. Forgot, if spraying starter fluid got the car started, the injectors would need to be working.
