Hello Everyone - thank you to the admin(s) for adding me here!
I have an 87 Colony Park and the vents are stuck on forward defrost - has been so since I picked her up.
I pulled the center front facia off to determine if the cable was working, and it does seem to switch. This is the Motorcraft p/n YH-380 (Ford: E1AH-19D961-BA).
There does not seem to be any vacuum leaks anywhere and my hoses all look good (did replace a couple of hoses around the upper manifold intake).
Would this YH-380 be the likely fault, or is there something much more finnicky that I need to tackle?
On a side note, the auto-release parking brake does not engage when I put her in gear. What is likely the cause?
Thank you all in advance!!
