Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: '87 Colony Park, stutters, bucks, and stalls. Help Pls!
  1. #1
    Jeff97062
    Mar 2022
    Tualatin, OR
    21
    Default '87 Colony Park, stutters, bucks, and stalls. Help Pls!
    I picked up an 87 Colony Park wagon with a 302 in it. It stalled a LOT for awhile, but I figured I'd get it sorted. Well, it's better, but only by a very little bit. I've spent 5 times what I paid for the vehicle letting a mechanic try to solve my issues. All to no avail. He fixed other stuff that probably needed fixing, but not the rough/stalling issue.
    Symptoms:
    - stalls at stop lights/signs
    - stutters and stalls when put into gear (idles in park just fine)
    - bucks when going up hills
    What I've tried to fix it, unsuccessfully:
    - replace fuel filter
    - replaced fuel pump with electronic pump
    - replaced fuel injectors
    - replaced fuel injector wiring with new wiring harness
    - replaced TFI
    - replaced Dizzy
    - Replaced sparkplug wiring
    - Replaced ECU
    - Bypassed SMOG diverter
    - Replaced fuel regulator
    - Replaced idle air control
    - smoke tested and fixed all leaking hoses that I could find
    Next steps I'm considering:
    - check spark with spark tester
    - check ignition to see if fuel is at constant PSI, even when stalls
    - Run new wire to fuel injector and ground properly (since old wire may be faulty)
    - Beat my head against the wall mercilessly....if nothing works
    I'm really at my wits end with this thing. Any help/suggestions GREATLY appreciated.
    1987 MGM Wagon
  2. #2
    GMN Regular
    Oct 2008
    St. Louis, MO
    859
    Dumb question, but when the distributor was replaced was it re-timed properly? Should be set with the SPOUT connector disconnected and at 10* before TDC iirc. Did you use an OEM Ford TFI module or aftermarket?
  3. #3
    Jeff97062
    Mar 2022
    Tualatin, OR
    21
    I think so. My mechanic did it. The TFI is after market
  4. #4
    Jul 2019
    Finland
    1,399
    Check TPS and EGR, bad spots in the TPS sweep or out of calibration. EGR valve might be full of crap and hanging open.
    http://www.grandmarq.net/oldfuelinjection/page30.html
  5. #5
    Mar 2006
    Bedford, VA
    6,798
    In addition to the above, I don't see spark plugs on your list. I'd replace those if they haven't been replaced. Get the copper ones, usually the cheaper choice at the parts store. Easy to do yourself if you have a few hand tools.
    I'd also check to see that the base idle is correct. https://www.muscularmustangs.com/idlereset.php
    There are some other idle troubleshooting tips on that website as well.
  6. #6
    Jeff97062
    Mar 2022
    Tualatin, OR
    21
    Thanks Fordman!
  7. #7
    Jeff97062
    Mar 2022
    Tualatin, OR
    21
    Thanks Tiggie! Will try all this and report back!
  8. #8
    GMN Regular WagonMan's Avatar
    Sep 2004
    Bridgewater Ct.
    936
    How many miles on the engine? Timing chain been replaced? WagonMan
    89 Colony Park
    90 Colony Park
    70 HEMI Daytona Convertible
  9. #9
    Dec 2021
    668
    May or may not matter but I wouldn't trust an aftermarket TFI. May be difficult to find an OEM but I would make to effort to do so.
  10. #10
    I post a lot...
    Dec 2011
    Yonkers NY
    4,680
    How does it run when not trying to idle?
    03 Marauder DBP, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
    08 TC Signature Limited, HID's Mods>235/55-17 Z rated Cooper Zeon RS3-A, Addco 1" rear Sway, Posi, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17
  11. #11
    Dec 2021
    668
    Actually, Rockauto shows it for an '87 GM which is the same part for about $86 (MOTORCRAFT DY1284 {DU2Z12A297A} should you decide to go that way. Haven't looked at EBAY to see if the price can be beaten or anywhere else, for the matter.
  12. #12
    Member TheEnglishChap's Avatar
    Jun 2022
    Lakebay, WA
    30
    I too have an 87 CP. So here is some thoughts (if you have not done these already).
    For the plenum on the upper intake manifold and throttle body gaskets, as well as fuel pump o-ring, I used aviation grease (not sure of the motor-world name) to help with the seals. This certainly solved my high-idle (turns out I had not greased the new IAC gasket and it compressed to the point of allowing air to sneak by it in one spot).
    If not greased, you may have to get new gaskets, plenum, etc...
  13. #13
    41,456
    1987 specifically sometimes had the old crappy single row timing chain. Would be worth checking that for slop. Only practical way of doing that without opening the engine is to remove the distributor cap and put a breaker bar on the crank. Rock the crank and note how far it turns before the rotor follows. A tight chain will be minimal movement, a sloppy one will have significant travel. If its loose enough it can give you erratic spark timing, and since fuel injector pulse comes from your ignition pickup, it makes that flaky too.
    ever scan it for codes? Sometimes that will give a lot of insight.
    honestly sounds like someone loaded up the parts cannon and just threw things at it. Some of that stuff may have needed replacing but the injector harness is not a typical fail item. Neither is the ECM. These things aren't that complicated, but they also don't have a lot in the way of self-diagnostics so it takes some obsolete knowledge (or the factory shop manual) to figure it out.
  14. #14
    Jeff97062
    Mar 2022
    Tualatin, OR
    21
    May be a good call TheEnglishChap. I put the idle air control in with no grease. I'll try that, along with the base idle check suggested by Tiggie.
    1987 MGM Wagon
  15. #15
    Jeff97062
    Mar 2022
    Tualatin, OR
    21
    Not sure on mileage. It rolled once or twice at 99,999,999. It say 44,XXX,XXX now. So could be 144 or 244. My guess is 144,xxx,xxx
    1987 MGM Wagon
  16. #16
    Jeff97062
    Mar 2022
    Tualatin, OR
    21
    Update-I checked spark on all cylinders, was okay there. I checked fuel pressure while driving. Hung around 30 PSI. Sometimes up to 39 or so, but usually around 29-30.
    Have replaced fuel pump, fuel filter (both done by my mechanic) also fuel regulator. That pressure seems way low. But what could be impeding flow if I already had all that crap replaced? Maybe something is bad, but that seems like a low percentage chance
  17. #17
    Mar 2010
    Lewisville, TX
    23,230
    fuel pressure is correct. Should be ~30 at idle (full vacuum) and ~40 at WOT (no vacuum).
  18. #18
    41,456
    yep, perfectly fine, allowing for gauge error and regulator tolerances.
  19. #19
    I post a lot...
    Dec 2011
    Yonkers NY
    4,680
    Does that thing have a map?
  20. #20
    41,456
    sensor, yes. firewall, above and behind the passenger side valve cover usually.
    I have had one go bad, and the engine ran extremely rich. Oddly it ran normally when unplugged. My best guess is the diaphragm inside broke and for whatever reason the position stuff sits in with vacuum and working is approximately the same position it sits in with no vacuum and broken.
