I picked up an 87 Colony Park wagon with a 302 in it. It stalled a LOT for awhile, but I figured I'd get it sorted. Well, it's better, but only by a very little bit. I've spent 5 times what I paid for the vehicle letting a mechanic try to solve my issues. All to no avail. He fixed other stuff that probably needed fixing, but not the rough/stalling issue.
Symptoms:
- stalls at stop lights/signs
- stutters and stalls when put into gear (idles in park just fine)
- bucks when going up hills
What I've tried to fix it, unsuccessfully:
- replace fuel filter
- replaced fuel pump with electronic pump
- replaced fuel injectors
- replaced fuel injector wiring with new wiring harness
- replaced TFI
- replaced Dizzy
- Replaced sparkplug wiring
- Replaced ECU
- Bypassed SMOG diverter
- Replaced fuel regulator
- Replaced idle air control
- smoke tested and fixed all leaking hoses that I could find
Next steps I'm considering:
- check spark with spark tester
- check ignition to see if fuel is at constant PSI, even when stalls
- Run new wire to fuel injector and ground properly (since old wire may be faulty)
- Beat my head against the wall mercilessly....if nothing works
I'm really at my wits end with this thing. Any help/suggestions GREATLY appreciated.
