'87 Colony Park, stutters, bucks, and stalls. Help Pls!
    Update-I checked spark on all cylinders, was okay there. I checked fuel pressure while driving. Hung around 30 PSI. Sometimes up to 39 or so, but usually around 29-30.
    Have replaced fuel pump, fuel filter (both done by my mechanic) also fuel regulator. That pressure seems way low. But what could be impeding flow if I already had all that crap replaced? Maybe something is bad, but that seems like a low percentage chance
    1987 MGM Wagon
      fuel pressure is correct. Should be ~30 at idle (full vacuum) and ~40 at WOT (no vacuum).
        yep, perfectly fine, allowing for gauge error and regulator tolerances.
          Does that thing have a map?
            sensor, yes. firewall, above and behind the passenger side valve cover usually.
            I have had one go bad, and the engine ran extremely rich. Oddly it ran normally when unplugged. My best guess is the diaphragm inside broke and for whatever reason the position stuff sits in with vacuum and working is approximately the same position it sits in with no vacuum and broken.
              It would be typical for the engine to run worse when this in unplugged so I suggest trying that.
              IIRC it could be a vacuum leak, bad harness or bad sensor.
              On another concern, the car does not pop back into the intake?
                Yeah... if the hose to the MAP sensor is crap, replace it. That could be the entire issue. If disconnecting the MAP does nothing or it runs better, the MAP sensor is toast.
                  Okay, will check that out. I thought mechanic changed the MAP. But that's the downside of doing some with mechanic, some by yourself. You don't always know for sure.
                  Thank you for the advice!
                  1987 MGM Wagon
                    One final thought on fuel pressure though, the issue is, even at WOT its still around 30. Shouldn't it be close to 40?
                    1987 MGM Wagon
                      After simple check of Map,
                      Does it backfire through the intake?
                      Check the throttle base setting.
                      Check firing order is NOT HO.
                      Make sure ECM is NOT HO.
                      Are you 100% sure the engine is not an HO? Could it have been changed in the past?
                        No, I have no idea if it's HO or not. Model is 1987 Mercury Grand Marquis Colony Park LS. The WINis 2MEBM79FXHX656764. Most of this is obvious, but not sure what you want to see to know if it's HO. Here's what the specs say on a VIN check:
                        Displacement(CI): 302
                        Other Engine Info: Cental Fuel Injection
                        Displacment (L): 5.0
                        Engine Power (kW): 111.8550
                        Engine Configuration: V-Shaped
                        Engine Number of Cylinders: 8
                        Engine Brake (hp) From: 150
                        Displacement (CC): 4948.893328
                        Engine Brake (hp) To: 160
                        NCSA Model: Marquis/Monterey (car version; for van version 2004 on see code 444)/Grand Marquis
                        1987 MGM Wagon
                          Ho (high Output) Motors, available in mustangs and Lincoln mark VII are very similar same size engines that are sometimes swapped into panthers. They have different internals and heads. perhaps most significantly here the camshaft requires a different firing order. And a different engine program in the ecm. So there are two 5.0 liter ford motors in the same years with two different firing orders and ECMs. I have seen people use the wrong order when installing new wires. Just something to check. If it is the original engine it requires the Non-HO firing order.
                            If the fuel pressure jumps from 30 to 40 when the vac line is removed, the reg is fine. At WOT it may not actually show an increase at peak fuel demand, depends on how healthy the rest of the system is. Either way that won't be why it idles badly.
                              You know, now that you mention it, the mechanic said he changed the firing order. He may have mistakenly changed it to HO, assuming it was same as foxbody 5.0 mustang. So today I'm going to check the following:
                              1) MAP and MAP line - disconnect and see if if run different.
                              2) Review firing order through dizzy into cylinder, make sure it's set for NOT HO
                              Hey, GrandMarq gang, thanks again for all the info on my beast! This is exactly why I buy project cars, to try new stuff (to me) and learn!
                              1987 MGM Wagon
                                I don’t know what u mean by pop back in the intake manifold. Do u mean are both end connected? Sorry for dumb question
                                1987 MGM Wagon
