PHP Warning: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead in ..../includes/class_bootstrap.php(433) : eval()'d code on line 106
My '95 Caprice Classic STW, "Sally" - Page 7
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 121 to 140 of 150
Thread: My '95 Caprice Classic STW, "Sally"
  1. #121
    41,823
    hm, guess that sits in there very different than I'd have expected. panther and even my S10 were a remove the bolts and jack the trans up a smidge to slide the mount in type of deal. No need to remove the x member or any of that crap.
  2. #122
    Jul 2019
    Finland
    1,526
    Basic idea is the same here, but it's complete nonsense to achieve in reality.
    Here's how it looks from below:
    Now that the Maisa is in storage, I parked the Caprice in the driveway.
    Heh, the people that lived in this house before us had a trailer and a car in the driveway lengthwise.
    With our trailer sideways scooted all the way back, the Caprice/MGM fits snugly on the driveway.
    Had to take some backroads to take a girl home after a party yesterday and the LED bar works wonders even in the wet unlit roads. Currently the sun sets after 6PM, but hell if it ain't dark at 3 in the morning aswell
    A guy wears a cool Ford Club hoodie when he goes out, what does he drive? A clapped out fooken' Chevy!
  3. #123
    41,823
    oh, yeah thats goofy looking. The Panther and S10 cross members were similar looking, basically just a flat thing with lots of room around it.
  4. #124
    Mar 2010
    Lewisville, TX
    23,653
    That exhaust on the one side that goes stupid close... there's really no need for that. What a mess. The 80s B-body I had didn't have that mess under it. It was closer to what the panthers have. Pretty easy to work with. Bah.
  5. #125
    Jul 2019
    Finland
    1,526
    That's an aftermarket exhaust, factory is true duals or Y-pipe in cases other than the LT1. Factory exhaust is routed a bit better atleast.
  6. #126
    Mar 2010
    Lewisville, TX
    23,653
    That's good, but still. That's some crazy routing.
  7. #127
    Jul 2019
    Finland
    1,526
    The dash fiddlefuckery has been performed twice now. The first time I did it the odometer and trip readings stayed unscrambled for approximately 1,5 hours.
    I opened the dash again the next day (saturday), I did the same thing again, but so far the digital readouts have stayed clear for a couple days and a dozen power cycles.
    The VFD screen attaches to the main cluster frame with 4 screw and 2 dowels to line up the contacts. The screen circuit board has flat solder spots onto which some spring loaded tangs rest onto.
    I just sanded and cleaned both contacts and slightly bent the tangs outwards for better pressure against the solder spots. Didn't see any cracked solder spots, which seem to be a common issue on these.
    Also I will no longer be basking in the warm orange glow of the CHANGE OIL -light, that bulb is now in the glove box.
    The car has been marking it's territory somewhat generously with engine oil. It's the front of the engine that's leaking.
    Looking online, replacing the Optispark & water pump oil seals are quite the job. I think it'd be worthwhile to do the timing cover and crank seal the same time.
    For now it'll stay leaking, because the weather is cold and it's a pretty big involved job to do.
    Seems like attaching images from local files is busted too.
  8. #128
    Dec 2021
    999
    Not a big fan of "repairs in a bottle" but have you given any thought to putting in any oil stop leak? Of course, if the seals are cracked or other damaged they won't work but if they are simply dried out they can offer some assistance. Something like ATP AT-205. I've personally seen good results, in limited instances, but might be worth a shot. I'd do an oil change first and then put it in. Just a thought to possibly save a lot of grief in repairs.
  9. #129
    Jul 2019
    Finland
    1,526
    Quote Originally Posted by friskyfrankie View Post
    Worth a shot surely, dunno about ATP but I've got Liqui Moly, Red Line and Motul stop leaks readily available, that ATP stuff kinda too but it's double the price.
    Dunno what to pick.
  10. #130
    Jul 2019
    Finland
    1,526
    Worth a shot surely, I've got Liqui Moly, Red Line and Motul stop leaks readily available, that ATP stuff kinda too but it's double the price.
    Dunno what to pick.
  11. #131
    Dec 2021
    999
    Not sure how those other formulas work but I have personal knowledge of ATP as I have many stories from others on it's success. I have no financial interest in the company but only personal experience. Sometimes, the added expense is worth it to get the results required. Let us know what you do and the results you get.
  12. #132
    Jul 2019
    Finland
    1,526
    Eh, I put in a bottle of the Red Line stuff, maybe it'll do something, maybe not. Not losing too many shillings on this, more bummed by the stains on the ground.
    I should probably clean the outside of the engine a bit to see better.
    Dash repair seems to be holding up. Relocated my just-in-case -stuff to the Caprice, sprayed some silicone spray around the door panels and arm rests to quiet down the creaking. Put in some rubber protectant on the door seals and lock grease on the door locks so they don't freeze during the winter. LED bar is now aimed properly, headlights might need adjustment, will have to see what the inspection guy has to say. Gotta get a cable for the block/interior heater and mount my interior heater somewhere.
    The headliner needs a couple thumb tacks. Still kinda want to chop the exhaust tips.
    Tuning-wise it'll stay as is. Engine control is from the performance tune and all trans parameters are from a stock tune.
  13. #133
    Jul 2019
    Finland
    1,526
    Found an Allis-Chalmers TL20 and Fiat-Allis 605B in a junkyard, expertly removed a Volvo bumper for a friends project.
    Went to Helsinki cruising, came across the friendliest parking warden in the history of man, saw a fire truck hit another fire truck, saw a BMW almost take air on a speed bump, broke into my car with a beer can.
    Good stuff.
    Attached Thumbnails Attached Thumbnails 20221103_143558.jpg   20221104_212754.jpg
  14. #134
    Jul 2019
    Finland
    1,526
    Next week is gonna get COLD as fck, had to get winter tires on today.
    Woke up at noon, ate, did some stuff, dad went to change the winter tires on his BMW and sister went to change the tires on her Jetta. We only have one floor jack, so one at a time...
    I got my turn with the jack at 2PM, did the rears and was supposed to grease the joints up front, no grease... Had to wait for dad to get back home so I'd have a car to go get grease, he was at a hardware store but left his phone at home, as usual.
    Got my grease, had to tear apart the grease gun, put it back together, cleaned up all the grease fittings on the car, messed with those for a while. Just barely managed to get the tires changed before 4PM, just as it got dark. Didn't really get to snap a proper pic.
    The outer tie rod boots are torn, one ball joint boot aswell, other than that, they're just old and crappy.
    Dunno if im really into the rallye wheels on this car, but they're on there now and they'll do.
    Not sure what should I do with the summer wheels, they're replica Centerline Auto drags, just pretty beat up and painted matte black. I'm torn between painting them gloss black and running them with factory 9C1 center caps, OR stripping the paint and redoing the factory brushed aluminium finish.
  15. #135
    Sep 2014
    Warren, MI
    7,076
    Add the basic Chevrolet hub caps with bright lugnuts and the wheels will look just dandy.
  16. #136
    Jul 2019
    Finland
    1,526
    Whaddayamean by basic Chevy caps? And on the winter rally wheels or the not-Centerlines?
    The winter wheels are the Chevy Rally wheels, 5 slots, hubcap nubs on the inside, near the bolt holes. They don't have the 3 holes for the bolt-on 9C1 center caps.
    The fake Centerlines have the 3 threaded holes for bolt-on center caps.
    I would kinda like the bolt-on caps on the Rally wheels, but I'd have to drill and tap 12 holes with pretty exact spacing. And buy the caps of course.
    These bolt-on caps, which I quite like:
    The Rally wheels fit caps like these, which I'm not really into due to the age of the car:
  17. #137
    Sep 2014
    Warren, MI
    7,076
    Yah, those ones with the bowtie on 'em. Those would look real good on those steel wheels, if you could get them on there. Remind me of the center caps (Didn't I call them "hub" caps? D'oh.) my van had, only those were metallic silver.
  18. #138
    Jul 2019
    Finland
    1,526
    Yup, those center caps came on a lot of different things, police spec B-bodies came with those center caps on police steelies. Looks pretty killer.
    If I can be arsed to fit those caps on the rally wheels, I guess that'd look nice aswell, since the rally wheel is pretty deep dish.
  19. #139
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,470
    That blue 67-69 Biscayne looks like a Chicago Police car. They have a unique blue color.
  20. #140
    Jul 2019
    Finland
    1,526
    Got the summer wheels cleaned up to the best of my ability.
    Removed all weights since I want to refinish atleast the faces. The wheel barrels are so corroded and embedded with brake dust, they won't come out with just cleaners. Wheel acid maybe, or blasting as a final solution. I'm not going that far.
    I took one wheel in to dry, gonna try some paint stripper on the face. I'll have to gauge the amount of work necessary to get the original brushed aluminium finish. If it's too much work I'll just end up repainting them either gloss black or silver.
    The faces have some dents on them, nothing too major. The matt paint is smooth, so hopefully the surface beneath is too.
    This is the best condition one of the barrels, the one I cleaned the most. Several passes with engine degreaser, HD wheel cleaner and a wire brush.
    Attached Thumbnails Attached Thumbnails 20221115_154501.jpg   20221115_154428.jpg
