Starting
    Starting
    In my 85 GM, you have to give it some gas every time you start it, even if I shut it off and right back on and stalls occasionally. Once you give it a little throttle it'll fire right up though
    Check/replace TPS maybe? On cold starts, does the "choke" engage? How does it run otherwise?
    You should check fault codes if it'll tell you anything.
    My '85 MGM always needed some throttle to start, or have the choke high idle cam engaged. But my CFI was pretty screwed anyways.
      Runs great otherwise. Just needs gas on starting and occasional stalling, usually when coming to a stop
        Well it seems like the high idle was set low, so I adjusted it higher and now it takes about 3 cranks without touching the gas pedal
          That's just how they are, my '85 was the same way. However, play with the idle and verify your throttle position sensor is OK. As Arquemann pointed out, make sure the choke-pull off mechanism works & engages the throttle when you stab the go pedal. That's actually required for starting per owner's manual. When hot, my '85 wouldn't start unless the throttle was cracked somewhat.
