So, the taillights work for turn signals, hazards, however when I step on the break only the high mount/3rd brake light illuminates. Fuses/bulbs appear intact, id assume its not the break light switch as the 3rd brake light illuminates. Any ideas ? Thanks for any tips.
'91 CV no taillights during breaking
This is most likely a problem with your turn signal switch (multifunction switch), and more specifically, probably the hazard function of the switch.
Because the turn signals and brake lights share the same bulb, the turn signal switch (or hazard switch) has to interrupt the brake light voltage to enable the voltage to be cut on and off by the flasher. Since your problem is both sides, I suspect the hazard switch.
Aggressively pull out and push in the hazard switch a few times, and re-test. If the problem is gone, now it may be fixed for a while, or maybe forever. If it does not work, my next step would be to inspect the wiring at the turn signal switch, and consider replacing it.
If it did work, I'd then try to make it break again by doing things like wiggling the hazard button or smacking the bottom of the steering column. If the lights stop working again, I'd replace the switch even if you can wiggle it into working again.
Originally posted by kishy View PostThis is most likely a problem with your turn signal switch (multifunction switch), and more specifically, probably the hazard function of the switch.
I was just dealing with a similar issue on my '78 LTD wagon. I second the multifunction switch. You can see how the brake light feeds through the switch on the wiring diagram. The switch isn't setup the same as on my LTD, but the circuitry is pretty similar still.1978 Ford LTD wagon, 351M
1979 Mercury Marquis, 351W
1987 Ford F-250 HD 4x4, 460, 4-speed, reg cab full bed
2003 Mercury Marauder, 4.6L DOHC, JLT CAI, 4.10 gears, J-mod, custom tune
It’s funny because I Just replaced that multifunction switch twice lol. The original was cosmetically not great. Purchased an NOS one via eBay however that one acted funky. Headlights only worked on high beam. So got an aftermarket multi switch, and this is the issue I’m getting from the 2nd new switch…lol
Originally posted by Hill185 View PostIt’s funny because I Just replaced that multifunction switch twice lol. The original was cosmetically not great. Purchased an NOS one via eBay however that one acted funky. Headlights only worked on high beam. So got an aftermarket multi switch, and this is the issue I’m getting from the 2nd new switch…lolWhat I Own: 1993 Mercury Grand Marquis GS
check the connections, maybe something is loose. Since the third light works, the brake light switch itself must be OK, and the signal is failing between the brake light switch and the output from the multifunction. I don't know if there is a connection between the brake light switch and the multifunction switch to check.86 Lincoln Town Car (Galactica).
