Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Power windows not working
    Default Power windows not working
    Windows wonít work from switchís but if jumped from battery they all work.I checked breaker under hood itís good checked fuse itís good I also checked relay and it is good what else do I look for thanks
    23,323
    Sounds like the driver door set of switches has an issue. Check the wires to make sure the one feeding power to that panel didn't break loose. The switch plate may have an issue as well.
    41,596
    yeah, verifiy you have power and ground to the switch in the driver's door. Power and ground run into the driver's door switches first, then through that switch to each door. Failure in the door harness can make all of them stop working.
    Got power to main switch and all other switches.I jumped main switch with battery and car battery unhooked all windows go up and down except drivers door then I jumped front door ground and all windows work except drivers front with car battery hooked up. Check continuity of ground from switch to door and that’s good now I don’t know what to do
    Dec 2021
    803
    So, the driver's window doesn't work under any circumstances? Do I have that correct? If so, check out the motor and/or gear set. If the driver's window works by bypassing the switch, you have your answer. Bad switch.
    Got power to main switch and all other switches.I jumped main switch with battery and car battery unhooked all windows go up and down except drivers door then I jumped front door ground and all windows work except drivers front with car battery hooked up. Check continuity of ground from switch to door and thatís good now I donít know what to do
    Did test for switch and it is good also bought new one just in case where do I check for ground
    Attached Thumbnails Attached Thumbnails 8CB9DE54-BD8B-4C5F-A1EF-7585E96EAB66.jpeg
    41,596
    check the EVTM, it will tell you which ground it uses.
    If applying power and ground to the switch directly makes it go, that sounds like you don't have power and/or ground. If you are using a meter, try testing voltage when the window switch is held down. It could be a bad connection that is allowing voltage but no current when unloaded.
    Ground is on door and on ground bus under dash I’ll check those.
    23,323
    IIRC, that circuit breaker coming off the fender mounted starter solenoid is the power to the windows. Might need to check and see if power is on the other side of that when under load.
    Still front drivers window not working changed window motor new drivers switch new 20amp breaker window relay and nothing got power to all doors.all other windows work from front switch just not drivers now I’m lost
    On another problem is mirrors not working is there a connector for the passenger side mirror under the dashboard
    Thanks
    23,323
    double check grounds for the driver door. If everything else is working, seems like the grounds are either broken or loose somewhere in the driver door or driver kick panel.
    Where is the ground at drivers kick panel
    23,323
    Once you pull the panel off, there should be a bolt in the body with one to 5 wires going to it (depending on options) just below the dash near the door.
    Donating Member massacre's Avatar
    Oct 2011
    USA
    669
    Is there a one-touch down module?
    I had one of those go bad and caused all kinds of problems.
    23,323
    Pretty sure it's a box and they didn't have those.
    Diagram shows g1303 inside Lh front door,near control switch
    G403 behind Lh center of I/P on ground bus
    Do you have picture of the ground
    Attached Thumbnails Attached Thumbnails 6D4E5A40-7B8D-4745-BD72-F5278D76AE1C.jpeg
    23,323
    No. I don't have the 88 any more to get that pic either. There may be enough of a difference between 88 and earlier cars that the body contact for the grounds may be in a different spot. I do know that my former 88, 93, 2000 and even my 03 Expedition have ground points where local accessories are grounded in that location, so I'm pretty sure yours should have a ground point to the body there too. I think the 82 Mark VI I had also has a ground point there. Should be about an inch from the door jamb, behind the kick panel, either down near the carpet or about 2/3 the way up to the dash IIRC. Basically look for wire(s) with a ring terminal that's bolted to the body.
    Ok I’ll look and my wagon is a 1987 forgot to mention that
    Was under dash tracing grounds and found this connector with plastic cover whatís this for
    Attached Thumbnails Attached Thumbnails D1F2EA48-54E9-448B-B196-DE6C260FC104.jpeg
