Results 1 to 6 of 6
Thread: Drum question
    Member 91merc's Avatar
    Jun 2022
    Oklahoma
    72
    Default Drum question
    I just replaced rear shoes and wheel cylinders on my 85, drums were in good shape but I have a squeak if I press very hard on the brakes. What could this be? First thing I did after buying the car cuz the old shoes were disintegrating and I didn't drive it before the new brakes
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,381
    Did you turn the drums even if they looked good ? What about new spring kits ? Both, in my opinion should be done.
    Jun 2022
    Oklahoma
    72
    Didn't do either of those
    Dec 2021
    658
    Lube the lube points on the backings?
    Birdsboro PA.
    17,878
    did you remove the rust ridge from the drums after installing the new brake shoes?
    41,446
    usually when I've had them squeak it was a ridge on the backing plate hanging the shoe up, and/or it needed a dot of grease on that spot.
