So I decided to change the trunk lamp and under hood lamp to LEDs( why did I do this? because I have nothing to do with my time;-( )
So the trunk lamp lamped up no problem. The under hood lamp, N/G.....I switched the lamps and the lamp is not the problem.
I then removed the socket from the hood and cleaned the S out of it with Caig "Red", and used steel wool to clean the the inside surround. Lamp still does not light, used steel wool on the pieces that join together from the harness to the socket. Still no light.
So how can I determine if the socket itself is shot (not receiveing 12 volts)...or what fuse protects this under hood lamp?
What is the procedure to test the socket itself? Where to place the test leads?
Thanks in advance to the assistance, assume I am a dummy and need to be guided like a child;-)
Thanks
