Results 1 to 8 of 8
Thread: Intake manifold coolant leaks?
    Member 91merc's Avatar
    Jun 2022
    Oklahoma
    75
    Default Intake manifold coolant leaks?
    I was driving my 85 GM home last night and I blew out some coolant, and when I popped the hood the only place I could see a leak looked like it was coming out from under the intake manifold. Is this possible or just spraying from somewhere else and couldn't see where from with a flashlight?
    Dec 2021
    665
    Sure it is not coming from the bypass hose or top radiator hose and traveling there?
    Jun 2022
    Oklahoma
    75
    Trying to figure that out now, it was hard to see in the dark
    Dec 2021
    665
    Better idea. While running it should give you an answer.
    Jun 2022
    Oklahoma
    75
    Upper rad hose it is
    Dec 2021
    665
    Cool! If that is your only issue, an easy and relatively cheap fix!!
    Jun 2022
    Oklahoma
    75
    Went ahead and replaced both rad hoses so that all the coolant hoses are brand new, those were the last 2 I hadn't replaced
    Dec 2021
    665
    Quote Originally Posted by 91merc View Post
    VERY smart move!
