Results 1 to 4 of 4
Thread: Replacing just the glass on an 03 pass. side mirror?
    GMN Regular
    Oct 2008
    St. Louis, MO
    879
    Default Replacing just the glass on an 03 pass. side mirror?
    Wife called to inform me that she clipped a mailbox coming through my friends neighborhood tonight. Luckily the housing itself is fine but when it folded in there was enough force to crack the mirror glass and knock it out of the housing. She was able to snap it back into place. It's not loose and the power adjustment still works fine but the glass is cracked.
    1. Is there a way to get a Ford replacement mirror glass for this or do I have to replace the entire assembly? This is a power adjust AND heated mirror
    2. If it's possible, anyone happen to have a Ford part # handy that I can search around for?
    6,831
    I'm seeing the glass only listed as 1W7Z17K707AA.
    EBay has an OEM https://www.ebay.com/itm/28368970247...mis&media=COPY
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,412
    Go to a auto glass shop and they can replace just the glass very quickly. Aftermarket glass is also available on line.
    GMN Regular
    Oct 2008
    St. Louis, MO
    879
    Thank you guys, appreciate it. Part # noted for future reference. Hopefully this will be the last time the "Objects in mirror are closer than they appear" theory is tested
