Results 1 to 9 of 9
Thread: 460 injectors?
    May 2017
    167
    Default 460 injectors?
    Got told by a mustang guy that 460 injectors fit on our cars due to the ev1 connection. Can anyone confirm? About to buy some from eBay
    Nov 2014
    Evans, GA
    2,005
    Quote Originally Posted by dan View Post
    Are you needing just a specific rate? Ford used the EV1 injector on many engines, just with different rates.
    41,549
    I think the 460 injectors were 24# blues. Physically they fit, but unless you tune the ECM it won't work right. I don't know exactly what you're trying to do so I can't tell you if they will actually work for you.
    but yes there are a lot of EV1 injectors that physically fit, but not all of them have the right spray pattern or flow rate to actually function.
    May 2017
    167
    Looking for some 24/25lb injectors. Asking because I got a stand alone computer and getting car ready for some boost in the next year or so. Plus at this point and time the sd computer doesnít like the intake and slightly bigger cam. Right now it idles at 1100 when warmed up and 900 in gear. Also shuts off when trying to drive when itís cold.
    Nov 1982
    Wetumpka, AL
    20,446
    Mark VIIIs have the #24 injectors too, thereís a few other applications that used them.
    May 2017
    167
    Found some 25lb on eBay for like 50$, just wanted to confirm that I could physically put them on lol. I didnít want to spend $300 on some mustang specific ones
    41,549
    if you're looking for boost, 24# isn't going to be enough. Mine gets fairly close to 100% duty cycle at full throttle and thats N/A with iron heads.
    May 2017
    167
    Thatís interesting, how big do you suggest I go?
    41,549
    There is some large size Seimens (I think) that are supposed to have excellent control even down to small duty cycles. 86VickyLX could tell you which specific ones he's using on his car, but they're supposed to be pretty excellent.
