Results 1 to 7 of 7
Thread: Mercury Switch, where is it located?
    I post a lot... Toploader's Avatar
    May 2013
    1,983
    Default Mercury Switch, where is it located?
    On my '86 MGM, the under hood light........I can not find the mercury switch, how does the lamp go off when the hood is closed???
    GMN Regular WagonMan's Avatar
    Bridgewater Ct.
    944
    The switch is in the housing where the bulb goes. When you open the hood, the ball of mercury slides down to make contact so the light comes on. I remove the bulbs under my hoods, the switch can fail and drain your battery if the light is on with the hood closed. I have a flashlight under the seat of my cars for emergencies. WagonMan
    89 Colony Park
    90 Colony Park
    70 HEMI Daytona Convertible
    May 2013
    1,983
    Quote Originally Posted by WagonMan View Post
    Pete bulb in my car just goes into the bulb socket, there is no housing??
    Bridgewater Ct.
    944
    There must be a spring loaded plunger type switch somewhere along the edge of the fender. Follow the wire from the hood light.
    WagonMan
    89 Colony Park
    90 Colony Park
    23,288
    The bulb socket has the mercury switch in it. The switch doesn't take up much of any room.
    Donating Member massacre's Avatar
    Oct 2011
    USA
    656
    This is what i was thinking as well. Aero hood and trunk lights are mercury switches and it's part of the socket and not big at all.
    Dec 2021
    758
    May be able to find a replacement OEM on EBAY if the original is faulty. Not sure if the original question was for informational purposes or there is an issue.
