Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Weird coolant leak
    Member 91merc's Avatar
    Jun 2022
    Oklahoma
    104
    Default Weird coolant leak
    On my 85 it seems to be seeping a little bit of coolant around the top edge of the timing cover, I put a pressure tester on it and it held the pressure good for about 30 minutes, but whenever I drive somewhere and park there's a couple drops of coolant on the ground and a little bit on the top of the timing cover
    GMN Regular
    Aug 2018
    905
    Check the thermostat housing for leaks. My 87 has a little leak there as well.
    Jun 2022
    Oklahoma
    104
    I looked and when I've been driving for a while, there's tiny bubbles on the top edge of where the timing cover mounts to the block, but it only happens after I shut the engine off
    Edit: no water getting in the oil, and could that top right water pump bolts cause it if it's not tight enough? We just replaced the water pump about 300 miles ago
    Nov 2014
    Evans, GA
    2,006
    Did you do the timing cover to block gasket? If not, that's likely your culprit.
    Jun 2022
    Oklahoma
    104
    Haven't done that gasket because this car's kinda just a budget beater for now until I can get the engine pulled out of my 91 and reseal it
    Dec 2021
    757
    Did you have the leak prior to doing the water pump? Appears others have alluded to this question. If not, you then have your answer.
    Jun 2022
    Oklahoma
    104
    I'd don't know, I bought the car with a radiator leak so I didn't drive it at all before replacing the water pump, radiator, etc
    41,549
    There is a seal between the pump and cover and another between the cover and block, so it could be leaking at either. The trouble with the block to cover seal, if it leaks inside the engine it dumps coolant into the oil. Keep an eye on that.
    if you do pull the timing cover to replace that gasket, just do yourself a favor and replace the timing chain and the crank seal while you're in there. 85 chains are crap, and the seal is like 4 bucks.
    If you want a really half-ass non-fix, if you take a loop of wire and put it under the dime-size bit of metal on the bottom of the radiator cap that will prevent it from building any pressure. Probably won't leak anywhere but if it runs over 212 at all its going to boil over.
    Jun 2022
    Oklahoma
    104
    20220814_183052.mp4
    Top right corner of the timing cover, only does it after driving for a while and shutting off
    23,287
    Yup. Timing cover gasket. That sucks.
    Jun 2022
    Oklahoma
    104
    Thumbs up
    And we just replaced the water pump about 500 miles ago so everything's gotta come back off
    Sep 2014
    Warren, MI
    6,962
    Ford says, "You're welcome. Yes, you may have another."
    ::insert Kevin Bacon meme from that one movie here::
    Jun 2022
    Oklahoma
    104
    Probably need to replace the timing cover anyways, we had to JB WELD a hole in it from the PO
    Dec 2021
    757
    It's not the right way but wonder if you can jamb some thick gasket maker into the area and let it cure properly before using. Could then leak from another weak spot but maybe worth a shot? I understand this is blasphemy but merely trying to save you a lot of work unless you need to do it all for another reason.
    41,549
    probably would just push the goop out. My bigger fear would be that its going to start mixing coolant in the oil, from there its a short trip to milkshake station with a siding of no main bearings.
    Jun 2022
    Oklahoma
    104
    Idk what to do with this car, replaced the entire cooling system but yet I'm sitting on the side of the road overheating
    Only thing we did different was a single core plastic tank radiator out of a 91 instead of the factory thick brass one, and an aluminum water pump instead of the factory cast iron
    41,549
    none of that will cause overheating unless the radiator is half clogged. A bad fan clutch will though. So will low coolant from a leak.
    Jun 2022
    Oklahoma
    104
    Well I'm looking it over and that top right bolt for the water pump is loose so hopefully that's all the problem
    Edit: the one that runs through the timing cover leak area was loose, and the rest took a good bump, so hopefully it's fixed
    Member Stocker's Avatar
    Jul 2014
    The Land of Sky-Blue Waters
    142
    I had persistent issues with my Cutlass running hot until I replaced the fan clutch (and installed a high-flow thermostat, but I put the old t-stat in a beaker of water on a hot plate with a temperature probe and it opened when it was supposed to).
    Quote Originally Posted by 91merc View Post
    ...and an aluminum water pump instead of the factory cast iron
    I didn't think they were interchangeable, but...
    These cars had two different water pumps available - one standard, and one for the heavy-duty cooling option. To buy one now, the standard pump is aluminum, the heavy-duty is cast iron. I don't know if the standard pump was cast iron in the past.
    1985 LTD Crown Victoria
    1996 Dodge Ram 1500 4x4, 360
    Nov 2014
    Evans, GA
    2,006
    Quote Originally Posted by Stocker View Post
    They can be swapped around. The cast iron pumps utilize an additional bolt where the aluminum ones don't, so you'd need a bolt that would fit (and probably a thread chaser to clean up the hole) if you tossed a cast iron pump on where an aluminum pump was. Obviously if you reverse that deal, you just have a bolt left over.
    As far as reliability goes, I can't really comment. I know my '87 has a cast iron unit, and when Nick was doing his Explorer swap, it got an aluminum pump. Both have been working fine. Guess it just boils down to the quality of the manufacturer.
