1991 P72 Box Aluminum Drive Shaft
    I know this has been beaten to death but I figured sharing more pictures is never a bad idea. My 91 P72 came with a steel shaft and 2.73 rear end. I installed a 3.55 limited slip rear end so to feel good inside I wanted a aluminum shaft. I also didn't want to use conversion u-joints so I found a AOD yoke that will fit the 1350 u-joint that the 2006 P71 shaft used.
Name:	New Yoke and U-joint.jpg
ID:	1290645Click image for larger version
Name:	Part Numbers .jpg
ID:	1290646Click image for larger version
Name:	Fts92003 Amazon.jpg
      Nice work and also like the tool arrangements!
        Thanks, tools make a fine back drop.
