It is misaligned and sluggish going into gear. I'm trying to source a prnd switch. Any part number or advice would be helpful. Thanks guys.
P r n d switch
What is displayed up on the dash is just a cable actuated indicator. There is no switch for changing gears. There is some adjustment on the indicator so the indicator lines up more proper to what gear you have selected. But changing out the actual indicator will result in no change in how a selected gear would engage.~David~
what they said, nothing electronic about the indicator.
The switch at the transmission is only used to turn on the reverse lights and allow the starter to run in P and N. If its going into gear slowly, thats an internal transmission problem, nothing to do with the indicator or the switch.
part number for the neutral safety switch
F0VY-7A247-A
the indicator assembly with the cable
E0LY-7A110-A without electronic cluster
E0LY-7A110-B with electronic cluster86 Lincoln Town Car (Galactica).
just in case you have any desire to dig around in the 80-89 Master Parts Manual, here it is
http://www.grandmarq.net/gadget73/MPM/
unfortunately its not a searchable PDF, so you have to navigate it like a less-convenient paper manual. This manual covers all the cars. Trucks are in another manual that I don't have.86 Lincoln Town Car (Galactica).
Originally posted by friskyfrankie View PostIf you take the column apart, many times you can zip tie the collar together to fix the issue. Most of the adjustments (assuming there are no other bad adjustments elsewhere)What I Own: 1993 Mercury Grand Marquis GS
Same basic concept, just the part where it attaches to the cluster is not the same.86 Lincoln Town Car (Galactica).
