rear disc brake hardware
    Looking to buy 96-02 rear disc brake hardware. The backing plate, caliper and bracket, cables etc. everything needed to upgrade to rear discs (except the rotors and pads). Anyone have some laying around?
    Thanks
    Phil, Not sure if this helps but I've got a couple of Marauders here that I'm parting out not sure of what's different between 02 & 03-04 but should have everything you need if it's the same.
      After finding some posts about them it appears they will work, with some additional effort. I like that they are vented compared to the 96-02 ones. I'll send you a PM. Thanks!
        Yes vented which is why I selected them. The only possible consideration would involve the addition of ABS comes to mind. IIRC the number of trips for the pickup is different and possibly a different hole for the sensor.
