My understanding is that as long as the fluid is in the "cross-hatch" area of the dipstick, you are fine. Just curious if there is an optimal (sweet spot) within that level. Does the trany "like it better" on the lower end of that, the middle or the high end?
AOD/AODE Optimal Fluid Levels
AFAIK as long as it lands in the cross-hatch area at operating temperature, everything's good. Don't want to overfill.
Having shifting concerns?
If you have leaks, high end. If you drive hard (turn sharp and lean hard), high end. If you drive for comfort and don't stress anything out, anywhere is fine.
Originally posted by Kodachrome Wolf View PostAFAIK as long as it lands in the cross-hatch area at operating temperature, everything's good. Don't want to overfill.
Having shifting concerns?What I Own: 1993 Mercury Grand Marquis GS
The hash marks are 1 pint apart, total capacity is a smidge over 12 quarts for a completely empty trans. Within that 1 pint range it doesn't care.
A lot of "transmission" problems are really engine problems, so intermittent nonsense might be a misfire.86 Lincoln Town Car (Galactica).
yes. Bottom of the hash marks is the "add 1 pint" mark, or at least it is on the AOD. Don't remember if its actually marked on the dipstick or just in the owner's manual though.86 Lincoln Town Car (Galactica).
Functional difference should be none, but since the pickup is through the filter at the bottom, it needs enough fluid in it to keep the filter well fed. I know I kept my 88 MGM at the top mark because I would lean that thing in corners pretty hard and didn't want the trans pump sucking air. My 93 has the newer pan with the drain plug and the matching filter with the drop tube so it sucks in the drain plug sump area. Before that upgrade I was sucking air at times in sweeping right turns at speed.
