I ran the stock wiring with a ring terminal clamped on it for a while. No issues. But when I started adding more electrical load, I upgraded the wires. It can be done, but it's not advised as a bad battery that allows the alternator to go full tilt trying to charge the brick will fry the stock fuse links in the wires after a while.
Alternator Capacities For '88 CV
Haven't looked into it but I am sure someone sells an upgraded (3G) alternator and complete wiring kit. Would have to use the same frame and belt, though as I probably wouldn't be able to convince him if too many changes have to be made besides me not wanting the extra work!What I Own: 1993 Mercury Grand Marquis GS
Originally posted by DerekTheGreat View PostI'll add that I did what I don't think anyone else has- I kept the factory wiring in addition to the 3G wire that came from a mid 90's Continental. I've put some 20 or 30k miles on the car since and it hasn't burned down. I agree with what someone else said, it looks factory, no one who doesn't know panthers has ever commented about it.
Not too concerned about the original wiring. I am sure it can be tucked, here and there enough to be hidden. More interested in the frame and belt/pulley matching up. Pulleys can be swapped but some alternator design makes that difficult if not impossible. It has been mentioned so I believe certain Mustang years (mid 90's?) are basically an easy swap.What I Own: 1993 Mercury Grand Marquis GS
LMR sells a 3G upgrade kit.
https://lmr.com/item/SVE-17046K2/Mus...rade-87-93-50L
Originally posted by sly View PostLMR sells a 3G upgrade kit.
https://lmr.com/item/SVE-17046K2/Mus...rade-87-93-50LWhat I Own: 1993 Mercury Grand Marquis GS
You can use the same belt, but it will be a little tighter due to the larger pulley. The bracket on the vehicle will sometimes need to be ground out to allow more movement at the lower bolt. The inside edge towards the crank pulley might need to be ground/milled to allow for the wider alternator case ear around that lower bolt. I did the grinding on the car when I did the swap on the 88 MGM I had. This left a lot of shavings on the front of the engine in the old oil residues. Since the bracket holds the power steering pump, I was not inclined to remove it from the car to do the grinding. Others have not needed to do any grinding. Mine needed about 3/8 to half an inch of lip taken off.
Yeah, it appears some grinding would be required unless you can find a 3G alternator that has the exact same dimensions. I guess it depends upon the alternator as to if you can swap pulleys so there is no difference in belt tightness.What I Own: 1993 Mercury Grand Marquis GS
I did not need to swap belts, but I put an alternator from a Windstar(?) on my car. There's a nub in the casting that prevents it from moving full range of travel, but I think that's in the loose direction. There is about 1/2 an inch of space left to tighten the belt if need be, no squeals. I don't recall swapping pulleys either, but certainly an option.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostI did not need to swap belts, but I put an alternator from a Windstar(?) on my car. There's a nub in the casting that prevents it from moving full range of travel, but I think that's in the loose direction. There is about 1/2 an inch of space left to tighten the belt if need be, no squeals. I don't recall swapping pulleys either, but certainly an option.What I Own: 1993 Mercury Grand Marquis GS
Having gone through two 3G alternators, the first one fit without grinding while the second required modification. The first came off a Taurus, the second a Mustang. But if you need to swap alternators on the road, the parts store might not have the one that just barely fits. It'd be more prudent to shave the bracket now.
Originally posted by friskyfrankie View PostDo you recall the year of the Windstar replacement?
For Taurus, just add a year at each end of the range ('94-'99).Vic
Originally posted by VicCrownVic View PostLooks like '95-'98 would be the right year range for the Windstar.
For Taurus, just add a year at each end of the range ('94-'99).What I Own: 1993 Mercury Grand Marquis GS
The 3G swap sticky should have that full list of vehicles. I helped compile that list several years ago for this site.
http://www.grandmarq.net/vb/showthre...upgrade-README
Yup... first post. Also verified all the links in that post are working.
Originally posted by sly View PostThe 3G swap sticky should have that full list of vehicles. I helped compile that list several years ago for this site.
Yup... first post. Also verified all the links in that post are working.What I Own: 1993 Mercury Grand Marquis GS
