Couple 3G Conversion Questions
Results 1 to 12 of 12
Thread: Couple 3G Conversion Questions
    6,882
    Default Couple 3G Conversion Questions
    I'm late to the 3G Game; I don't want my 90 to burn up with the classic 2G...
    I'm reading the various threads on here. One direction calls for reusing the stock charge wires, together on a single ring terminal. Others call for a new charge wire with fuse.
    I'd like to be minimally invasive to the factory wiring and also maximum fire safety. Best to run a new charge cable?
    23,658
    If you replace with a 95A alternator, the stock wires on a single ring terminal should be enough. You still run the risk of blowing the fuse links at the starter solenoid stud. I didn't have any issues initially. But I later upgraded the charge cable as well before the battery had any issues that would cause a problem like that. Replacing the charge cable definitely gets max safety factor and you can use the 130A alternator with no issues. Check the sticky for purchase options (links to kits and parts were recently updated) and what you'll need to grind for clearance to get the belt on without removing both bolts. If you don't mind removing both bolts, you don't have to do any grinding to the lower bracket.
    http://www.grandmarq.net/vb/showthre...upgrade-README
    Sep 2014
    Warren, MI
    7,076
    I put the two charge wires on a ring terminal and also ran a separate charge wire harvested from a mid 90's Continental. 40k+ miles and some six years later, no fires.
    6,882
    I think I'll go for the new wire then. Got a 130 amp unit. I would have been fine with a 95 amp, but there were none readily available at the junkyard.
    Being a 90, the charge wire connector at the fender well has four wires in it instead of three, the extra being the green/red for the warning light.
    Here's the plan (suggest edits as needed)
    - keep charge harness plugged in at fender well to maintain the green/red battery light and yellow/white for stator wire
    - unplug factory charge connector on the 2G.
    - continue use of unmodified voltage regulator plug/harness.
    - cut stator wire near 2G charge plug, add 3G pigtail for stator wire.
    - run 4ga charge wire with fuse (175 amps seems like a lot?) to battery side of starter relay.
    I'll clean up the wiring and remove to 2G charge plug once I find a 90/91 harness I can cut up and make visually appealing.
    Here's the odd duck connector. I incidentally, I have an extra 86?/89 harness with the three wires instead but that won't do me much good on this car.
    Nov 2014
    Evans, GA
    2,056
    Your plan sounds solid to me. You can just tie your old charge harness somewhere out of the way and route the new one as you see fit.
    175 amp fuse is just good protection in case something decides to short out real bad.
    23,658
    Sounds like a good plan to me.
    Donating Member massacre's Avatar
    Oct 2011
    USA
    711
    Sounds good. 175a might be a little too high, maybe not. Fuses should be sized to protect the wiring, you want the fuse to pop before the wire burns up. There are some charts online that can give you a ballpark on how big of a fuse to use on 4 gauge wiring, depending on the length.
    If 130a is the maximum the alt will put out, 150a might be a little better (safer) than a 175a. Or if it's a short run, 175 might be fine.
    41,823
    175 is what Ford put on those alternators in the Taurus.
    Oct 2011
    USA
    711
    Did the Taurus use 4 gauge?
    41,823
    Not sure if it was 4 or 6. I've pulled those cables before, its actually long enough to do the job on a Panther so long as you don't mind it being yellow. Its been a while though.
    Oct 2011
    USA
    711
    23,658
    Yes, 175A is standard issue for 130A alts.
