3D models for printing unobtanium parts
Results 1 to 11 of 11
Thread: 3D models for printing unobtanium parts
    23,647
    Default 3D models for printing unobtanium parts
    I'm making this thread for printing off parts that are unobtanium.
    I'm starting with the Aero/Whale door striker bushing. I will print this out next week and make sure it fits.
    http://www.grandmarq.net/sly/3D/Ford...etric_Bolt.stl
    Dec 2021
    990
    Couldn't view the part - "Invalid Public Key"
    23,647
    It's an STL (mesh) file. You will need 3D printing/modeling software to see it. The 3D paint program in Windows 10 should be able to render it.
    Dec 2021
    990
    I'm still using Windows 7 (heh, it still works great). Wonder if there is a conversion program for that type of file. What type of material are you printing them with?
    23,647
    download FreeCAD. It will open STL files.
    23,647
    Also, Windows 7 will still upgrade to Windows 10 for free (if you want). Download the media creation tool from M$ and when it asks what you want to do, select "upgrade this PC". I've done this a few times at work over the past couple of years... well after when it was supposed to be disabled.
    Dec 2021
    990
    Been thinking about it but the computer is from 2008 (or so) - not sure how well and even if Windows 10 will like it. Too many projects to play with it now but it is on my "possible to do list"! As far as costs, I believe you can still do it for free.
    Dec 2021
    990
    Downloaded FreeCAD and was able to open the file. Looks good and many thanks for the program info!
    23,647
    Had to change the length by .5 mm shorter. The curve of the bolt to the head doesn't let it fit quite right. I'll upload that at lunch. The current one can be ground down 0.5mm and work fine or take a countersink or half inch bit and shave a bevel in that end.
    23,647
    Ok. Final version in place.
    Also, any models posted will be added to the top post.
    23,647
