Can someone tell me what position the wiper motor dial points in while at rest? Fabricating a setup to use 2005 wiper motor on the swap I’m doing and need to get the motor arm at the right start point. It works currently just need to tweet it. The wipers are going down about 2” initially then going up. Perhaps give a number on a clock for reference. Thanks.
84 Wiper Motor Arm Resting Location
Should be clocked exactly the same IIRC. The only difference between any of them is the mounting bolt positions, wiper arm connection method, and wiring.
