Rubber Rear Control Arm Bushings
    Are new rubber bushings still available for the rear control arms? I can't seem to find them anywhere...considering swapping my poly's for the rubber for better ride quality
    -Phil
    I'd check with MOOG or a similar company directly. Most available seem to be "fronts" only.
      That's super weird, they are very oddly missing from everywhere.
      P/N is K200968, just for the curious. I bought four about three or four years ago, but that was then.
        I always thought it was the same thing used on Mustangs and everything else with an 8.8 for the bushing that actually goes in the diff ears. Those are available, but different p/n
        the Ferd manual says D9AZ-5A638-B for 80-82, replaced by E6AZ-5A638-A for 80-89 Ford and Mercury
        thats the only part number in the back, so all 8 are the same.
        Lincolns are of course different, E0VY and E6VY prefixes, even though its the same rear suspension. Probably different durometer rubber.
        I wonder if its just a durometer thing. Its the same ES kit for Mustangs and Panther cars, so that makes me think the dimensions are the same.
            The Mustang and Panther bushings on the diff ears are different sizes if i remember right. I recommended spherical bushings for Mustangs here on the site, and someone here bought them and said they didn't fit. I feel bad about that but honestly didn't know or else i would not have recommended them.
              Problem with actually replacing rubber bushings is you need to push the shells out of the arms too. You will need a press and proper stack-ups to not crush the arm and rip the extrusion in the stamping.
              I may have some in a box. Lemme look when I get home from work.
                I have 4 Clevite 62037's out of their boxes, never installed. Paypal me some shipping and you can have them. I did use one or two as spacers to weld boxing plates to upper arms over the years. I ordered them from rockauto maybe 10yrs ago and never installed them because ES poly didn't require a shop and labor $ only my time/labor.
                  Should also note they are 53mm diameter, 61mm long.
                    I know I purchased spherical diff ear bushings for the mustang and they are WAY too small to fit in the panthers diff ears.
                    I'll put them in my pops 85 (with swapped in 8.8 rear) one of these years.
                      Wow some great info here! Sorry for the delay. Jeff I'll send you a PM. Thanks!
                      -Phil
