Results 1 to 17 of 17
Thread: Removed the vinyl top
    Feb 2005
    Southern Minnesota
    1,782
    Default Removed the vinyl top
    It was close to 50 degrees today so I went out to the storage unit and removed the vinyl top off the LTD. I found one fairly large rust hole and one pin hole rusted thru the roof.:pissed: I still need to pull the trim and remove all the fuzz and adhesive. Then I'll have to weld up all the holes. Hopefully I can get it done without warping the hell out of the roof.
    pickup man boXman's Avatar
    millville PA
    8,410
    What are ya doin' with the Landau lights from the C-pillar?
    '95 Ford Bronco XL -
    http://grandmarq.net/vb/image.php?type=sigpic&userid=39&dateline=125548186  3 :rebel:
    Feb 2005
    Southern Minnesota
    1,782
    I already promised the lights to a friend of mine.
    Feb 2005
    Southern Minnesota
    1,782
    Yep rust sucks!! I think I win the award for the rustiest box on this site!
    Fack da Hulk Hogan! Grand Marquis GT's Avatar
    Nov 1982
    Hamilton, AL/Little Rock AFB, AR
    19,476
    Wow, lookin' like you are making progress!!!
    What do you use to get the glue and fuzz off effectively?
    Quote Originally Posted by sniper308 View Post
    Everybody have some of crazy the difference is that some have a little less and some have a little more, I have a little less combined with some of eccentric. :heyhey:
    ATT, SNIPER 308. " YOU HAVE TO BE MY EYES " Tomb Raider.
    Quote Originally Posted by DuceAnAHalf View Post
    this.
    if your letting your girlfriend run your life like that, congratulations your a bitch. grab my pocket, i just bought you for two packs of cigarettes.
    Feb 2005
    Southern Minnesota
    1,782
    It's not much progress but it's something.
    For removing the adhesive I use lacquer thinner, a wax and grease remover and a DA sander.
    There's no welders in Heaven, they all went down to hell
    Apr 2005
    Chesterland, Ohio
    3,183
    You must be going through sanding disks like candy.
    I cant wait to find all the surprises hidden under my vinyl roof!
    Feb 2005
    Southern Minnesota
    1,782
    I bought 2 100 count boxes of sanding discs just for the LTD. But I'm not going to start sanding until it's warm enough to paint. And right now it's only 34 degrees out.:pissed: I don't need anymore rust then I already have!! Once it warms up into the 60's I can start sanding, welding and painting.:welder:
    central VA
    12,008
    WAIT!!!! this has lights on the outside of the C pillar??? I never seen those!!! Got any pics of them before the top removal??
    Feb 2005
    Southern Minnesota
    1,782
    This is the best pic I've got of the roof with the light.
    The lights came on the LTD Landau's. I've got a 79 sales brochure with some good pics of the lights. I'll scan in the pics tomorrow.
    millville PA
    8,410
    You never saw the Landau lights, Pete?!
    central VA
    12,008
    Nope! never seen em till now...
    Quote Originally Posted by Fordman75
    My 79 LTD brochure actually came in the mail today But thanks for offering! and yes I think Id like some... but would they look good on a slick top? Im eventually going to remove my top.
    Fort Wayne IN
    5,312
    I had never seen those lights either. If I was to put lights on, Id do like a merc.
    Usual Suspect Freshmeat's Avatar
    Nov 2005
    Geismar, LA, USA
    3,498
    You planning to remove that metal strip where the front of the vinyl ended?
    It looks like you're off to a good start. I use Kroil (very lightly) on adhesive. I had some gum/adhesive remover, but it sucked like you wouldn't believe.
    Feb 2005
    Southern Minnesota
    1,782
    Yep I'm going to remove both trim pieces I circled in the pic below. I'm also going to remove all the trim along the lower part of the body and wheel wells.
    Nov 2005
    Geismar, LA, USA
    3,498
    Nice. I keep meaning to remove more trim, but it's kinda pointless if I don't get it running first.
