The message center has its own brain and would be a huge task to install. You'd need the brain, all the buttons, all the wiring, Gadget knows what else. If you can get all that in, you could probably find the right sensors to use, but wiring it up would be complex. The fuel level meter requires a special sender to be installed also.
I have a wiring diagram for the speedo and message center around here somwhere, Ill see if i can get some readable pics of it.
I do know what wires do what on the digi speedo itself, and I got it to work as a standalone unit, if that info will help.
