Results 1 to 9 of 9
Thread: Cleaning engine parts like alternators.
    Driver N A's Avatar
    Sep 2005
    Massachusetts
    1,491
    Question Cleaning engine parts like alternators.
    What's the best way to clean them and prep them for paint? Just hit them with some 220-400 sand paper, blow them off with compressed air then brush on paint?
    '90 Mercury Grand Marquis GS
    Baseline 5.0L numbers totally stock, 123 rwhp, 239 rwtq
    4.6L swap coming soon.
    Fack da Hulk Hogan! Grand Marquis GT's Avatar
    Nov 1982
    Hamilton, AL/Little Rock AFB, AR
    19,466
    Quote Originally Posted by N A
    Use brake cleaner to prep them after sanding, as well...
    It is notorious for cleaning very well, drying fast, and leaving no residue..
    Quote Originally Posted by sniper308 View Post
    Everybody have some of crazy the difference is that some have a little less and some have a little more, I have a little less combined with some of eccentric. :heyhey:
    ATT, SNIPER 308. " YOU HAVE TO BE MY EYES " Tomb Raider.
    Quote Originally Posted by DuceAnAHalf View Post
    this.
    if your letting your girlfriend run your life like that, congratulations your a bitch. grab my pocket, i just bought you for two packs of cigarettes.
    Driver N A's Avatar
    Sep 2005
    Massachusetts
    1,491
    Thanks for the info.
    24,848
    good carb cleaner I find generally works better. 2+2 = teh win for paint prep. Just be careful what and where you spray stuff. It will dissolve the varnish on the internal windings, possibly causing shorts. If you really want to paint it, I would probably take it apart and paint the case without the guts in it.
    Driver N A's Avatar
    Sep 2005
    Massachusetts
    1,491
    I'll scuff it up and blow it off. Wipe it clean with brake or carb cleaner and paint with a brushable, high-temp silver paint.
    Don't use carb cleaner, it leaves a mild lubricant on the surface.
    Use brake cleaner.
    Driver N A's Avatar
    Sep 2005
    Massachusetts
    1,491
    I just bolted it on. I'll remove it and take it apart when I paint it.
    Mar 2005
    Virginia Beach
    8,209
    Quote Originally Posted by 91gmblack
    Use brake cleaner.
    Some carb cleaners do, not all. Most of the higher priced ones do not leave an oil residue. Good carb, or brake cleaner does work very good though! I would also recomend removing it and painting just the body.
    24,848
    :stupid:
    2+2 doesn't leave a film. Cheapie Advance Auto crap does. The Wal-Fart junk does too.
