The Street Scoop I bought for the LTD showed up today. I sat it on the stock 2V carb just to get an idea of how it's going to look. With my 4V intake and carb the scoop will sit somewhere around 4-6" higher then it is in these pics. I think it should look pretty cool sticking thru the hood.
The Street Scoop I bought showed up.
:slug: :slug: :slug:http://secondhandracing.com/Home.aspx
You mean you don't want that on top of a 2bbl carb? Why not? Ohhhh you're holding out for the famed Variable Venturi carb. I get it.86 Lincoln Town Car (Galactica).
It's going to look sweet, but are you going to pick up any hp or is it just for show? Any drag strips, chassis dynos, G-Tech Pro meters or some way to measure any improvements?
'90 Mercury Grand Marquis GS
Baseline 5.0L numbers totally stock, 123 rwhp, 239 rwtq
5.4L swap coming soon.
Originally posted by N AIt's going to look sweet, but are you going to pick up any hp or is it just for show? Any drag strips, chassis dynos, G-Tech Pro meters or some way to measure any improvements?http://secondhandracing.com/Home.aspx
The scoop is mainly for looks. I was going to run the Boss 429 hoodscoop. But with my intake/carb/carb spacer setup the boss scoop wasn't tall enough. And having the carb and standard air cleaner sticking thru the hood(without a scoop covering it ) just didn't appeal to me. I've always like the looks of the street scoop with it's working butterflies. The main benefit is looks but it also acts as a cold air induction set up like Duce was saying. And at higher speeds you can also get some ram air effect on certain vehicles depending on how high the scoop sits above the hood.
Duce the scoop is held onto the carb using the mini air cleaner. You've got the scoop shell, mounting base(which is also the aircleaner base ), air filter and and air cleaner top. I wouldn't run a scoop without some kind of filter.
Oh yea they didn't nick name these scoops birdcatchers for nothing!!
Im thinking about either one like yours or the Hilborn style that is an open front with a mesh inside of it.http://secondhandracing.com/Home.aspx
