Results 1 to 7 of 7
Thread: Signs the Neutral Safety Switch is shot
    Loves his old junk zwack88's Avatar
    Dec 2004
    Nebraska
    4,984
    Default Signs the Neutral Safety Switch is shot
    Ok I have been searching everywhere and can't really get a straight answer. Ok so as some of you know I was looking at swaping out the trans on my vic this summer. When it is a WOT it seems to wrap up like I hear the engine reving up but it really is losing it to the wheels. I think it is my tranny. It has always been messed up because it sometimes would search for gears and the od would be really sluggish to engage. It has never slipped and when I took my vic in last year for a tranny flush at the dealer they said everything looked good in there. I have been wondering cause the Neutral safety switch is a $20 part and it would be a hell of a lot cheaper and easier then if I replaced the whole trans. I guess would that be a possible cause? I got my tune and it firmed up the shifts and it helped the searching alot. I don't know but this thing has been haunting my car since I bought it and everything checks out? Could the clutches be worn and not grabbing like they should thus causing this huge feeling of loss of power? It doesn't slip that I can tell and the fact it was clean when you drop the pan. At 3/4 throttle it will throw you back in the seat but at WOT it will not.
    Sorry for the long post I have been frustrated about this fucking tranny way too long. I will be greatful for any help.
    Mar 2005
    Virginia Beach
    8,217
    The nuetral saftety swith does nothing but prevent you from starting the engine if you are in gear. It's hard to tell, but it looks as if you are asking if NSS is causing the slipping. Is this what you are asking? Slipage can be caused by two things. The clutches not applying (valve body issue or a bad seal somewhere in the tranny) or it can be caused by warn out clutches.
    Dec 2004
    Nebraska
    4,984
    Ok thanks for clearing that up for me.
    Mar 2005
    Virginia Beach
    8,217
    NP :thumbsup:
    Johnnyiroc
    Guest
    all the NSS does is eep you from starting a car in gear. I think maybe you wanna look at the MLPS....This is what tells the tranny-computer what position the lever is in, R, OD, D, !-2
    35,324
    The Manual Lever Position Sensor is the one to suspect, since it controls shifting like JohnnyIroc said. I think its adjustable slightly but not a clue on the procedure. I know it can cause funky and no-shift conditions though. Anyone know if the MLPS doubles as a neutral safety switch on the electronic trans cars, or do they have a seperate switch for that?
    Horse's Ass mephistopheles's Avatar
    Apr 2005
    Auburn, AL
    242
    The MLPS acts as the NSS in 4R70W transmissions.
