picked up some heads yesterday
    Mid 70's era Windsor 351 Heads.
    194 intake valves
    160 exhaust valves
    intake ported, exhaust ported and polished.
    They were on a car that ran 12's (84 mustang)
    Should open up her up some
    Pics when it's light
    GMNRadio DJ, Podcast Co-Host
    1984 Ford LTD Crown Victoria - Drag Car.
    99 Ranger 2.5 - Parts hauler and Pit truck.
    03 Mustang 3.8 Convertable - Head Gaskets fukered up
    95 S10 93 Accord
    When are you going to bolt them on?
    '90 Mercury Grand Marquis GS
    5.4L swap coming soon.
      After machine work and installation of rotating assembly
      I had to get them now though because the guy I bought them from was going to take them to a swap meet next weekend.
      Paid 250 for em, no valves or springs. Just going to buy the valves and a cam kit then take em to the guy that's doing the machine work on my block to do a valve job
      95 S10 93 Accord
        i thought your block was poopy? have to open it up 30 over?
        grand_marquis_gt: "Wow dude, you got the GMGT sedan!"
        there, now im cool too
          the block that was in the car (ie the engine that was in when i bought the car) is crap
          The block in my sig is the one getting rebuilt. I bought it a while back out of a low mileage 84 grand marq.
          95 S10 93 Accord
            ah, i see. thatll work... but i would have gotten an 85 and done a roller assembly in it. unless you want the numbers to match up or something.
              i'm just rolling with what I can get good deals on
              i got that engine and tranny for $200; the heads for $250; 86 Mustang GT multiport upper/lower intake with all sensors, injectors, fuel rail, harness, computer, throttle body for $200
              95 S10 93 Accord
                Not really gonna be able to use that fuel rail I don't think. Might need to pick up a stock panther rail and the lines from the frame rail to the fuel rail. There is a connector down near the frame. I'd assume the frame rail lines are identical from CFI to SEFI but the lines on the motor itself aren't.
                  why you say that on the fuel rail? if i'm using all the components from the same car it should work, i think.
                  Or are there clearance issues?
                  95 S10 93 Accord
                    pics!
                    95 S10 93 Accord
                      Fox body fuel rails are different from the Panther chassis. Fox body rails have the fuel inlet and return on the same side(passenger side), Panther chassis has the inlet on the passenger side and the return on the drivers side.
                      If you are going to attempt to convert a CFI car, I suppose it would be easy enough to run the return line on the passenger side to make the Fox body rail work.
                        Ahhh, thank you!
                        95 S10 93 Accord
                          yeah, what he said.
                            Nice that the heads have screw in studs and guide plates.
                            The 86 HO engine has a smaller throttle body than 87 up and a smaller bore in the intake for that throttle body.
                            Tom
                              How about a ported lower intake 200 bucks?
