Results 1 to 2 of 2
Thread: Saw a complete 90 towncar at the junkyard last weekend
    Default Saw a complete 90 towncar at the junkyard last weekend
    I got to see the tubular exhaust manifolds up close.
    I understand this is the only year for that body style with the 5.0 engine.
    Anything worth getting from it?
    Also saw a couple boxes with Z code axles. Not sure the 3.08 traction lock is worth the effort.
    Tom
    24,837
    Get the fan shroud. Its a unique one-year part that can swap onto a box to replace the existing overflow tank. Add a windshield wash bottle from a late model car, and you have the perfect spot to run a cold air intake.
