Results 1 to 15 of 15
Thread: Subs and Amp install tips
    Dec 2005
    Philadelphia, P.A
    649
    Default Subs and Amp install tips
    Just got my tax refund in the mail today, which turned out to be alot more than I expected. So, im going to buy a cheap set of subs and an amp soon. Any tips and precautions that I should take installing subwoofers in my car? I never done it before but I can rewire speakers and have the tools to do electrical work. Even have a volt meter, circuit testor, etc.
    SOLD - 1987 Mercury Grand Marquis LS "Grandpa Special" 2 door. Now panther-less.
    My cardomain site for more pics:
    http://www.cardomain.com/ride/2128327
    central VA
    11,978
    there not really much to it if you have worked with wiring before - use the channel under the door sill to run wires. the link in my sig has plenty of general stereo install info.
    87 2 Door CV
    Apr 2006
    London, Ontario, Canada
    224
    Its pretty basic like 85crownHPP* said. Some things I can think of...Make sure you know how to wire the subs together. Its not hard but you can blow the amp. I've seen it done a few times. Make sure you use a grommet for the power wire going through the firewall, you don't want the metal to cut through the jacket and ground out. Keep the gain at miniumum on the amp untill the install is done. I've seen people max it out before, then turn it on, could blow the speakers. I can't really think of anything else...
    What are you planning on buying?
    pdeav ltdcrwnvic's Avatar
    Apr 2006
    El Paso, TX
    186
    yup yup, make sure all power/volume/frequency, etc is turned down to a minimum. when installing my new subs and amp, i finished everything and when i turned on the amp on the headunit, the power was full blast and there went one of my subs (
    Dec 2005
    Philadelphia, P.A
    649
    Couple of other questions, might have more as I am getting all the equipment together. Do I need to dynomat the trunk lid or should I dynomat just inside the trunk, under the carpet & carboard? I will be running two 12 inch Alpines (600 watt, 300 rms?) with a 760 watt Pioneer amp but they won't be putting out alot of power right now on the stock replacement alternator.
    Also, should I put tweeters in the dash or would they be overkill? I have pioneer 6.5 inch speakers in the doors and Pioneer 6x9s and both have tweeters in the cones.
    central VA
    11,978
    Definitly do the trunk lid, Id think that would rattle more than the rest of the trunk. Also stick some on the back of the lisence plate.
    Adding tweeters at a higher level than mids is always a great idea. It will give you a more filling sound that seems to be all around you.
    Photobucket Paul_'s Avatar
    Milton, NH
    9,234
    When I wired my stereo up in the Vic, I lucked out and had a hole just big enough for an amps power cable hidden under the dash on the passenger side. I ran that though there, behind the kick panel, and then under the door sill. Coming out of the trunk are my RCAs and my remote wire. Those actually are coming up from the package tray. I have the rear defrost on the back window, and the power line goes from the bottom of the grid under the package tray. The hole is big enough to route wires through one at a time.
    Save a seal, club a liberal.
    Dec 2005
    Philadelphia, P.A
    649
    For wiring in tweeters, can I wire them into the headunit using the extra set of inputs or are they similar to wiring in regular speakers? I never wired in tweeters before so I'm not sure what I can/can't do with them.
    Paul229, was there a hole in the firewall that you put the amp power cable through or did you go through one of the big grommets in the firewall?
    Milton, NH
    9,234
    It was just a hole. I'm assuming a grommet had been there at some point. It's real low in the dash too.
    Dec 2005
    Philadelphia, P.A
    649
    Bringing this thread back from the dead. So, for those who have wired up subs or an amp, where did you run the ground? Would I be allright grounding it to the trunk lid supports?
    Also, my amp has some settings I'm not familiar with. Such as the crossover setting, sub sonic, etc? Its an Audiobahn intake series, most people are surprised how powerful they are. I have a friend that uses the same one in a neon and it pushes two older JBL 12's very hard. I will only be running one 12 for now.
ID:	2032   Click image for larger version.
    24,837
    Subsonic would be for frequencies below audible. Its for that earth shaking feeling that the super stereo cars have. You can't hear it but your chest will vibrate and its very possible to fry speakers with that.
    The crossover is a high pass, low pass, or full pass deal. For subs you want low pass, so it cuts off anything above a certain frequency, high pass is for mids and tweeters so they don't get overpowered by bass. Full just amps everything.
    Ground in the trunk should be fine. Mine is attached to some bolt on the rear wheel well, but any solid body part should make a good ground as long as its clean and paint free.
    central VA
    11,978
    scott and I both have our grounds on the trunk hinge support bracket thing and so far so good. Im outting 600 watts of power through it tops, probabaly a lot less though.
    my ground is on the trunk hinge, it's perfect.. also make sure that your gain is turned way down on your amp until the install is finished, then you change your gain back to your desired level..
    also, i have 2 15" rockford stage 1's in my trunk with a rockford amp and my trunk rattles like crazy.. i've already had to sillicone the trim back onto my trunk twice, but my liscense plate does not rattle.. it sounds good in the car but i can't find the rattle outside, it sounds like it's inside the trunk.
    Dec 2005
    Philadelphia, P.A
    649
    I did my entire trunk except the lid with home depot duct insulation, which was similar than dynomat and only $16 for a huge roll. It worked great for me, but you might need something better for sound competitions.
    I would check the gas door, it rattles badly with the one 12 im running with only 400 watts to it. I insulated it and haven't had a problem with it since. Also, check the trunk lid itself and the hinges.
    WARNING DON'T DERP AND DRIVE!
    Jul 2006
    'Cada Oregon
    4,686
    We want to do something like this on the benzo it has a sony Xplod head unit and a alpine 6 disk changer stock
