i went to service the computer i traded for the grey towncar, and as karma would have it was just a loose connection, however the towncar wouldnt start.
observations.
this seems to be a slightly different from my 86. the coil harness is ghetto rigged and im not sure if the wires are on properly. theres a red wire an a green one.
there appears to be a fuse on the alt wire, but the fuse isnt clear so i cant see if its good or not. (forgot my tools)
i could smell fuel but when i pressed on the fuel rail valve after priming the pump with the key fuel only dribbles out. i was expecting a large spray.
so this leads me to beleive either hte fuel pump isnt putting pressure enough? (i can hear it run tho) so maybe try filter?
the iac motor looked spliced.
other than that it looked ok i guess. all the windows work, theres 5 turbines, and a steelie spare.. trunk motor worked, antenna worked... didnt try the moonroof. the vynil is severly sun damaged tho.
pics to follow
observations.
pics to follow
