Results 1 to 8 of 8
Thread: Unusally heavy vapor mists coming from the dashboard!(OFF)
    n00b
    Dec 2004
    Scranton,Pa.
    2
    Default Unusally heavy vapor mists coming from the dashboard!(OFF)
    It's one thing after another, This is unusual, at least in my limited experience. My 84 TC has a "vapor mist" with an antifreeze /"oil" smell that comes from the dashboard after I start it ,sometimes it's "heavy" as soon as I start the car. Other times it doesnt get bad until it runs for 15 min. In any event I know my heater core is shot.But even at this rate "should the mist be "so thick" at times it looks like there's something burning inside the car? It's so bad you cant sit in the car while it's running. Theres more,.. I think I have a loose valve cover or bad gasket on the "passenger side" of the engine because the engine starts smoking after it gets hot ,but only comes from that bank. I'm also aware that the heater core is in that area as well! Could they( the two mists) be connected?? Am I looking at something unusual or at something disastrous!!
    Prineville, Oregon
    21,587
    Get that heater core replaced. I have seen cores bust open and pour coolant into the car. Also Check for leaking oil from the passenger valve cover. oil is probably getting on the exhaust manifold.
    Welcome to GMN btw!
    Tremont PA.
    15,318
    if the steam smells like antifreeze,it's the heater core..........it's approx a 5 hour job to replace it, but well worth the effort for heat lol
    scott
    Mar 2005
    NY
    54
    I realize this is an old thread, but...
    I have this exact same problem (fog in the car, steam/smoke from under the hood). How urgent is this problem? If I only drive it for 2 miles at a time (cold starts each time), from home to school, will I be OK? How much will this repair cost me?
    1987 Mercury Grand Marquis
    5.0L V8
    Performance Mod Status: Planning Phase
    Interior Mod Status: Planning Phase
    Fack da Hulk Hogan! Grand Marquis GT's Avatar
    Nov 1982
    Hamilton, AL/Little Rock AFB, AR
    19,476
    Welcome!
    Where do you live? If you live in a hot climate like me, just bypass it, lol...
    Quote Originally Posted by sniper308 View Post
    Everybody have some of crazy the difference is that some have a little less and some have a little more, I have a little less combined with some of eccentric. :heyhey:
    ATT, SNIPER 308. " YOU HAVE TO BE MY EYES " Tomb Raider.
    Quote Originally Posted by DuceAnAHalf View Post
    this.
    if your letting your girlfriend run your life like that, congratulations your a bitch. grab my pocket, i just bought you for two packs of cigarettes.
    Mar 2005
    NY
    54
    Unfortunately I live up North where heat is a necessity...
    5.0L V8
    Nov 1982
    19,476
    I direct you to 5.0/5.8 tech forum!
    I have made the heater core post a sticky!
    this.
    Mar 2005
    NY
    54
    Default Thanks
    Hey thanks for the help... I ended up bypassing the heater core. I had a leaky hose anyway, and since it's spring now, and since I don't have the money to replace the heater core, this is a good temporary fix.
    5.0L V8
