Ive been thinking about doing a manual trans swap on my Marquis (its a 99) for a little while now and i was wondering if anyone has ever seen anything on this subject anywhere. The car has around 198,000 hard miles on it, the trans isn't slipping or anything else but ive been kicking the idea around for a little while now. I know that its not gonna be a simple swap i'll have to mount a clutch pedal, cut a big hole in the floor pan and make it look like it belongs there, and then see what needs to be done for a trans crossmember, driveshaft, etc. Any links, pics or suggestions would be awesome. Thanks
Manual Trans Swap?
There's a few of us that have done it in boxes I'm not sure about whales though.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
http://www.crownvic.net/drock96marquis/5speed.htm
^^all the information can be found there. Do not have to be a member to see that particular page, but since im bored, ill copy and post it all here to make things easier for you guys.
Parts:
For parts which do not have a number listed, order the part from your dealer for a 2000 Mustang 4.6l GT w/ 5-speed/t-45 unless specified otherwise.
Mustang GT T45 Transmission (-DONOR VEHICLE- (Ian used a 2000 GT))
6-bolt modular flywheel (FRPP/Ford or Ram Billet Are good options)
Modular flywheel bolts (F6ZZ 6379 AA) (ARP P/N 254-2801))
Pilot Bearing (F6ZZ-7600-A)
T45 Clutch (10.5”/11” per flywheel choice) (Owner’s choice-Ian used a King Cobra clutch for his CV.)
Ford Throw-out bearing (order for 2000 GT 4.6l w/ t45)
Ford clutch fork (order for 2000 GT 4.6l w/ t45)
Clutch Fork shield
Ford M8 pressure plate bolts
Ford T45 modular engine plate/adapter (F6ZZ-7007-EA)
T45 drive shaft yoke (order for 2000 GT 4.6l w/ t45)
Clutch pedal position/safety switch
Slave cylinder (ie Wilwood Pull Slave or similar can be used)
Stock , comparable year range civilian CV/GM steel shaft,
-to retain or use a p71 aluminum or AMMC shaft, a 5/8" or equivalent drive shaft spacer can be used
Suitable t45 shifter (preferably setup with some machined parts to be located further back, though really not required)
Clutch pedal assembly:
This will be up to you. There are MANY different clutch pedals which will work for this application - even modifying the Mustang’s unit.
If hydraulic clutch is desired- virtually any clutch pedal will do.
The clutch pedal is up to the person swaping. A mustang clutch/brake cage could be modified onto the panther brake cage. Then run the cable quadrant and cable to clutch fork.
The clutch pedal is the main amount of fabrication work involved with the swap.
Finding a clutch pedal that works is up to the person doing the swap, as there are so many potential options.
Ian used a 240SX pedal as he got it for free
Here is how he got it to fit:
The 240SX pedal has to be heated to have the curve taken out of it so it doesn't hit the brake pedal. After straightening it also needed to be shortened. Some people cut the middle out of the pedal arm and reweld it back into one. Ian chose to grind the welds on the pedal pad off the arm cut it at the bottom to where I need it and reweld the pad higher up.
This is a better method than rewelding the arm as it is thick steel and would require multiple passes which could be questionable for those who are untrained
The clutch pedal mounts right where the PCM resides. (hence PCM relocation ***Non-issue for 05+ owners)
Any surrounding gaps should be sealed/weatherproofed to prevent moisture intrusion/ cabin water leaks.
The PCM can be mounted on the fender liner. (ala 05+ panthers)
The spot is fairly moisture resistant (save for engine washing) - but a water tight case for it would be ideal
You’re on your own for the water-tight (or close to it) case. But it should be easy enough.
Technical Notes:
4R70W and the non-Cobra T45 have the trans mount in the same spot. Use a GT t45 to save some headache.
96-98 GT uses a unique transmission case, the Cobra uses one that I THINK is the same as the 99+ cases. The GT case has the mount further back.
-Again, the cobra T45 has a unique trans mount location
PCM will require relocation. On -04 models the PCM should be preferably moved to a moisture resistant area (in cabin) or, more easily in the engine compartment in a weather sealed ‘box’
02 Sensor wiring must be salvaged from AUTO trans harness
Tuning is required - I recommend Lonnie @ www.blueovalchips.com He specializes in unique swaps.
After you remove the column shifter, shift tube, shift cable etc. - remove the auto-trans DTR (MLPS/ transmission range sensor) from the original transmission, plug into the harness, and leave in the Neutral position to allow vehicle to be started
-Note, this should only be used a temporary solution as the vehicle would be able to start in gear
-The sensor should be mounted so that it isn’t just loose and flopping around - otherwise it will get damaged quickly. ‘Zip-ties’ may prove useful as a temporary mounting solution.
-The vehicle will not crank with this sensor (MLPS/DTR) absent, so make sure you don’t forget to plug it in and move to neutral during initial testing
-The shift cable does not need to be in place for this
The Neutral safety switch wiring (part of/is the auto trans MLPS harness) should be wired to the new clutch pedal position switch. This will allow the vehicle to only be started when the clutch pedal is depressed.
-This may be required in many states in order to pass inspection
96-98 Mustang t45 use a more traditional VSS system like 1992-2002 panthers. The panther VSS and wiring should be swapped over to the new trans.
99+ Mustang t45 use a revised OSS for speed signal, however, it appears the old VSS can be swapped in place.
-This should not be an issue on 03+ panther t45 swaps, though.
-After the old VSS is swapped into the new trans - match the right gear to what RAR your car has depending on what output gear is on the transmission. 4R70W and T45 may have a different output gear, 5, 6 or 7 tooth.
-On 03+ re-use the VSS block off plate that came from your 03+ (note, later build 03, and all 04+ don’t use a block off plate. One may need to be fabricated)
There is also a metal cover that shields the clutch fork opening from the elements. On the older mustangs it was a rubber boot.
The T-45 is shorter than the 4R70W w/ extended tailshaft housing
-For p71 and Marauder owners who wish to retain their stock aluminum (or AMMX) drive shaft, a 5/8" spacer is required
-A Comparable year civlian steel driveshaft can be swapped instead
-Town Car owners must use the drive shaft spacer option, as their is no OEM shaft available that is only slightly longer
-For those willing, a custom driveshaft can be made
Pics of "funkyrider's" t45 swap can be found on his supermotors page.
http://www.supermotors.net/registry/7603/55223
Thanks for all the thorough info! Sounds easier than i thought it would be, but anything mechanical seems that way in print, i'll be sure to do a thorough write-up with pics when i finally get to it. My room mates dad just gave him his 94 CV and when we finish fixing an 02 cavalier his brother will be giving him his 96 CV. We might use the 96 as the test car since he also likes the idea of having a manual CV. This would also be a good warm up so that my daily driver isn't down for nearly as long since i'd have a better idea of what to expect the second time around.1999 Grand Marquis
