GMN Chat Room    GMN's STORE!!    GMN's Gallery
Go Back   GrandMarq.NET - Panther Headquarters > Technical > Box Tech > Drivetrain/Chassis
Drivetrain/Chassis Suspension, Chassis, Drivetrain, Brakes. Everything to do with handling. Also includes transmission discussions.
Reply
Thread Tools Display Modes
Old 11-23-2009, 08:21 PM   #1
hemihotrod402
Anyone can restore a car, but it takes a real man to cut one up.
hemihotrod402's Avatar
hemihotrod402 will shine on, baby!hemihotrod402 will shine on, baby!hemihotrod402 will shine on, baby!hemihotrod402 will shine on, baby!hemihotrod402 will shine on, baby!hemihotrod402 will shine on, baby!hemihotrod402 will shine on, baby!
Send a message via AIM to hemihotrod402 Send a message via Yahoo to hemihotrod402
Default How to safely drop 2" ride height
I have asked several members on here and the only answers I have gotten are the 1 inch drop speedway springs. I can live with 1 inch, but im really looking for 2 inch. I know hav24wheel dropped his (when he had it) about 3 inches in the front, but i believe he heated the springs (hence safely). I also want to improve cornering ability as well, I have have the PI rear sway bar and I am getting the front. Suggestions?
__________________
Andrew, Certified Car Nut in Training
17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer.
hemihotrod402 is offline   Reply With Quote
Old 11-23-2009, 10:14 PM   #2
mrltd
He who shall not be mentioned.
mrltd's Avatar
mrltd will shine on, baby!mrltd will shine on, baby!mrltd will shine on, baby!mrltd will shine on, baby!mrltd will shine on, baby!mrltd will shine on, baby!
It's too much of a drop to do with just springs-if you want to keep the geometry correct. The upper control arm mounting point has to be moved up.
You can get any heavier spring and cut them to the ride hieght you want.
__________________
former builder/owner of badass panthers.
mrltd is offline   Reply With Quote
Old 11-23-2009, 10:35 PM   #3
CheeseSteakJim
I love it when a plan comes together
CheeseSteakJim's Avatar
CheeseSteakJim is dead sexy, and knows it.CheeseSteakJim is dead sexy, and knows it.CheeseSteakJim is dead sexy, and knows it.CheeseSteakJim is dead sexy, and knows it.
Send a message via AIM to CheeseSteakJim
If only there were some way to make drop spindles...
__________________
CheeseSteakJim is offline   Reply With Quote
Old 11-23-2009, 10:41 PM   #4
mrltd
mrltd's Avatar
Quote:
It's easy, just expensive!
__________________
Old 11-24-2009, 06:05 AM   #5
hemihotrod402
Quote:
explain, please?
__________________
Old 11-24-2009, 01:10 PM   #6
mrltd
mrltd's Avatar
Take the car to a prototyper and have them make a one-off spindle. My guesstimate is about $5K.
The one inch drop and the right wheel/tire combo is very nice. The handling is quite impressive also. Not to mention the ability to go over speedbumps.
__________________
Old 11-24-2009, 01:52 PM   #7
hemihotrod402
ook then 1 inch it is lol
__________________
Old 12-03-2009, 01:58 PM   #8
hav24wheel
is fixin shit that's not broke
hav24wheel's Avatar
hav24wheel will become dead sexy soon
or you could get heavier front springs (1400 pounders)and slowly cut them down tell you get the hight you want..... After I lowered mine i did have it alined and they didnt have any problems getting into spec.. It couldnt possably go any lower in the front than mine was without a spindle swap.. it was just touching the stock bumpstops on the front..
__________________
94 F-150, and a 78/85/92 F150,350 combo sittin on 44s. N yes I sold the Vic.
(I'm a uneducated asshole.)
hav24wheel is offline   Reply With Quote
Old 12-03-2009, 04:03 PM   #9
mrltd
mrltd's Avatar
Just because they could align it doesn't mean the geometry is correct. Bumpsteer, camber/caster gain all are thrown off when dropped too far.
Also, the more you remove from a spring, the rate increases...
__________________
Old 12-03-2009, 07:04 PM   #10
1987cp
Irish-American Dingo Whacker and Certifiable Retrogrouch
1987cp's Avatar
1987cp is almost famous1987cp is almost famous1987cp is almost famous1987cp is almost famous1987cp is almost famous1987cp is almost famous
Send a message via AIM to 1987cp Send a message via Yahoo to 1987cp
Don't they make drop spindles for B-body Chevrolets? According to that crazy demolition guy who came buy, Chevy spindles will bolt right up to Ford balljoints.
__________________
1987cp is offline   Reply With Quote
Old 12-03-2009, 07:05 PM   #11
1987cp
1987cp's Avatar
Quote:
I'd start with a pair of 700s and go from there if you like things stiff. IIRC one coil off would be about 850 lb/in and would drop the car a pretty good amount. Remember, the spring rate will go UP when you cut it.
__________________
Old 12-10-2009, 08:04 PM   #12
hemihotrod402
Quote:
i have seen 2 inch drop spindles for a B Body, but I did not know there was I possibility they could bolt up. Im asking for the speedway springs for christmas, along with beefier shocks, might just play around with the stockers rather than cut up a set of 200 dollar springs and see what results I get.
__________________
Old 12-10-2009, 08:09 PM   #13
mrltd
mrltd's Avatar
the stockers won't really have the rate to drop it. You will be bottoming out when you hit any bumps.. And the springs should only be 100 bucks a pair.
__________________
Old 12-19-2009, 10:23 PM   #14
hemihotrod402
i wasnt going to dirve with it, I was going to cut them to the desired hieght to see what it looked like. then If I liked it, I would take the speeddways under the knife.
200 bucks= 2 pair 100 bucks each
__________________
Old 12-20-2009, 10:18 AM   #15
Pirate
The Original Happy, Go-Lucky Pirate
Pirate's Avatar
Pirate will become dead sexy soonPirate will become dead sexy soon
I'd like to see a thread titled; 'How to unsafely drop the car 2"?'.
__________________
Daily Quote: “Why can't you find one single Democrat member of congress who is running for reelection by bragging on his vote for ObamaCare?” - Neal Boortz
Pirate is offline   Reply With Quote
Old 12-20-2009, 03:33 PM   #16
Darkmerc
Darkmerc's Avatar
Darkmerc needs the rep
Quote:
Explain to them the right way to do it then.
does not matter if they are cut or designed to lower, if the shocks are stock comfort tuned, there will be bottoming out.
Darkmerc is offline   Reply With Quote
Old 12-20-2009, 04:39 PM   #17
hemihotrod402
Quote:
dude, its pirate, its what he does. If he didn't, this place would be boring. Everyone finds humor in it.
__________________
Old 12-20-2009, 05:18 PM   #18
hemihotrod402
and actually, How to unsafely drop a car 2 inches would be pretty fucking funny
__________________
Old 12-21-2009, 12:44 PM   #19
johnunit
johnunit will shine on, baby!johnunit will shine on, baby!johnunit will shine on, baby!johnunit will shine on, baby!johnunit will shine on, baby!johnunit will shine on, baby!johnunit will shine on, baby!
ways to unsafely drop a car 2 inches:
Place Geo Metro on roof
Place fat chick in car (not recommended)
Drain air from tires
Remove rims, dismount tires, re-attatch rims.
Mount Geo Metro rims and tires
Apply heat to upper and lower control arms until weight of car bends them upwards
Place fat chick in trunk (preferrable to method 2, will only lower rear end)
__________________
85 4 door 351 CV with 15X,XXX KMs- stock and with issues...for now
johnunit is offline   Reply With Quote
Old 12-21-2009, 02:01 PM   #20
hemihotrod402
lol at not recomended
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
www.rockauto.com Official ScottFest 09 Home!
Review grandmarq.net on alexa.com
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
grand marquis, marq, mercury, lincoln, towncar, town car, crown victoria, vic, maurader, ford, panther, box, country squire station wagon, country squire wagon, lincoln town car, 91 town car, 92 town car, 93 town car, 94 town car, 95 town car, 96 town car, 1995 town car, 1996 town car, 1997 town car, 1998 town car, 1984 town car, 1985 town car, 1988 town car 1989 town car, limo town car, 2007 crown victoria, 2008 crown victoria, crown victoria lx, crown victoria car, 1994 crown victoria, crown victoria repair, 84 crown victoria, crown victoria forum, grand marquis forum, lincoln town car forum, mercury grand marquis, 302 specs, 302 engine, 302 performance, 302 efi, 5.0 302, 302 windsor, panther, panther chassis
