| GMN Chat Room GMN's STORE!! GMN's Gallery |
| Drivetrain/Chassis Suspension, Chassis, Drivetrain, Brakes. Everything to do with handling. Also includes transmission discussions. |
Thread Tools | Display Modes |
#1 |
so i followed the "Recipe" for speedway springs here. bought 925s for the front and 175s for the rear. problem is, the ass end of this wagon sits real low now, the car has a slight rake to it. any amount of weight in the rear seat or rear cargo area and the car scrapes hard on bumps and inclines, driveways, etc. i upgraded the rear shocks to Monroe 58568 units like here; http://catalog.monroe.com/monroe/par...8568&viewCode=
i've thought about putting in spring helpers in the rear but frankly it seems like i should just buy stronger springs. question is - which ones? |
#2 |
Scott's Automotive Service
if i remember correctly, mrltd is running stock wagon cargo coils on his wagon with 99 f150 2wd rear shocks.......it works real well. i've driven and ridden in his car
i installed the rear speedway motors springs in toms 87 vic and i noticed they sat a little loose when the suspension is hanging
__________________
1986 lincoln towncar signature series. 5.0 HO with thumper performance ported e7 heads, 1.7 roller rockers, warm air intake, 65mm throttle body, 1/2" intake spacer, ported intakes, 3.73 rear with trac lock, 98-02 front brake conversion, 92-97 rear disc conversion, 1" rear swaybar, 1 3/16" front swaybar, 16" wheels and tires, loud ass stereo system, badass cb, best time to date 15.94 at 87 mph. lots of mods in the works 221.8 rwhp 278 rwt 1989 crown vic gt sedan 5.0 HO 1991 lincoln mark VII bill blass (mini me) 1992 mercury grand marquis, 5.0 HO conversion finished, more to come! 1982 efm and 1986 alaska stokers keeping me warm
#3 |
Usual Suspect
Stock wagon coils are something like 14" and 185#. Your new springs are 12" and 175#, which guarantees a lot of drop and less support. I'm going with a 200-225 in my wagon once I get around to new springs.
__________________
2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets. 1992 Explorer Eddie Bauer, slight lift, 34s, and A/C... 1990 Crown Victoria, '10 Mustang 18s, '04 intake, 3G, 925/225 springs... |
#4 |
small engines suck
What he said. The Speedway springs are intended to lower a sedan. Station wagons got higher rate springs because they weigh more. You might want to just stick the stockers back in there for now to get the rear ride height where it belongs.
stock wagon spring specs: Product Specs Part Number 8795 Inside Diameter 5.000 End Type 1 Pigtail End Type 2 Pigtail Bar Diameter 0.625 Install Height 12.69 Load in Pounds 790.0 Spring Rate 182.0 Free Height 17.04 Rear Coil Springs By comparison, these are stock sedan springs. Note the much lower spring rate, but not a big difference in installed height: Product Specs Part Number 8649 Inside Diameter 5.050 End Type 1 Pigtail End Type 2 Pigtail Bar Diameter 0.531 Install Height 11.63 Load in Pounds 630.0 Spring Rate 107.0 Free Height 17.27 specs from here: http://www.grandmarq.net/vb/showpost...94&postcount=7
__________________
86 Lincoln Town Car (Galactica). Drivetrain: 5.0 HO, Explorer cam, FMS 1.72 roller rockers, 3.55 K code rear, tow package, BHPerformance ported E7 heads, Explorer intake, 65mm throttle body, Hedman 1 5/8" headers, 2.5" dual exhaust, ASP underdrive pulley, SuperCoupe stall converter Suspension: Bridgestone Protenza G019 225/60/16 on LSC turbines, 1 3/16" wagon front bar, 1" PI rear bar, cargo coils, KYB GR-2 front shocks, F150 rear air shocks, big front brakes, ES poly front suspension bushings, 00 CVPI steering box, ES poly body mounts, rear disc brakes 91 Lincoln Mark VII LSC SE, triple black (Timewarp) - poly front bushings, KYB struts and shocks. Last edited by gadget73; 02-03-2010 at 05:13 PM. |
#5 |
Usual Suspect
Okay- so has anyone dropped a wagon with the Speedway springs?
__________________
#6 | |
Quote:
its terrible and thats why i'm posting here. anyone want pictures of how idiotic it looks. if the actual spring had some support, i would not mind the drop. looks rad until even one human adult takes a seat in the rear then its low rider central. in terms of factory, are there cargo VS standard springs? i guess the factory ones are going back on but with the speedway springs up front i'm concerned its going to look and drive like a drunk pig. |
#7 |
The Box..Think Inside It
I'd like to see a picture. I may even want to take them off of your hands if you dont plan on keeping them.
__________________
~David 1987 Crown Vic. ![]() Mods: Mustang Headers into Mustang H-PIPE, B&M Shift Improver Kit, High Output Upper Stuff, 1/2" Intake Spacer, Mustang Valve Covers, Bumped Timing, 2009 Police Zip Tube and Air Box, K&N Air Filter, 3G Alternator, Under-Hood Fuse Box, Headlight Relays, Police Rear Sway Bar and Wagon Front Sway Bar.....and much much more. All around fun car to drive. BOX PARTS FOR SALE CLICK ME: NOS 1979 D.Side Clear lens, police gauges, electrical stuffs etc.... lets make a deal. Make some offers. LTB BOX PARTS : Chrome Pedals, Transmission Cooler, seat belt sleeves, 90/91 Relay housing/cover...Please Contact me |
#8 |
Usual Suspect
The cargo coils have a 200# spring rate. I think if you put Speedway's 200-225# springs on there you'd be cooking with fire.
__________________
#9 | |
Quote:
right but they have a lower installed rate than the stock wagon ones so the car would still, in theory, sit real low in the ass end. unless i'm totally wrong, which i'd be ok with because i'd really like matching spring brands front and rear! |
#10 |
Usual Suspect
After hearing your situation I'm planning the 250s in the rear of my wagon. The Speedways are 3" shorter so you'll want stronger springs to help limit rear sag. Stock is only around 185 on the rear so a 250 should work out well. Post a picture of yours, though- I'm curious how it looks.
__________________
#11 |
#12 |
According to Tom's Readers Ride page these are what 925 fronts and 225 rears look like:
So in theory then, the 175 rear springs would sit even lower?
__________________
#13 |
Usual Suspect
That's on a two door. Wagons are much heavier in the back.
__________________
#14 |
I still believe the question I asked is quite a universal one.
__________________
#15 |
Usual Suspect
A 175 would likely sit slightly lower than a 225, yes... But it also has a lot to do with how much weight is on the springs. I don't think the sedans and coupes have enough sprung weight on the rear to make a huge height difference between 175s and 225s.
__________________
#16 |
milking the funky ball of tits from outer space
Id just put sedan variable rates in the rear to slightly lower a waggin
__________________
Pete ::::>>> resident LED addict and CFI defector LED bulb replacements91 Crown Vic (ugly cream-puff) 85 LTD Crown Vic (HPP project) 88 P72 (new beater) I'm old gregg! 85HPP's most noteworthy mods: CFI to SEFI conversion w/HO upperstuff headers & flowmasters Towncar seats LED dash light-show center console w/5 gauge package LED 3rd brake light 3G alternator mini starter washer/coolant bottle upgrade Towncar power trunk pull underhood fuse/relay box 16" HPP wheels - police swaybars w/poly rubbers Soon (maybe): big brakes, 3.55L, shift kit, possible explorer bits swap and MAF conversion |
#17 |
Usual Suspect
I just ordered mine. 925/225. I meant to switch to 250s for the rear but in the process of doing it on my iPhone I forgot to switch them over. I guess we'll see what 225s look like on a wagon soon.
__________________
#18 | |
small engines suck
Quote:
David: assuming the same spring height, yes a 175 in/lb spring would sit lower in the same vehicle as a 225 in/lb would. If the spring height is not the same, then it may not be so.
__________________
86 Lincoln Town Car (Galactica). Drivetrain: 5.0 HO, Explorer cam, FMS 1.72 roller rockers, 3.55 K code rear, tow package, BHPerformance ported E7 heads, Explorer intake, 65mm throttle body, Hedman 1 5/8" headers, 2.5" dual exhaust, ASP underdrive pulley, SuperCoupe stall converter Suspension: Bridgestone Protenza G019 225/60/16 on LSC turbines, 1 3/16" wagon front bar, 1" PI rear bar, cargo coils, KYB GR-2 front shocks, F150 rear air shocks, big front brakes, ES poly front suspension bushings, 00 CVPI steering box, ES poly body mounts, rear disc brakes 91 Lincoln Mark VII LSC SE, triple black (Timewarp) - poly front bushings, KYB struts and shocks. |
#19 |
hmm decision, decisions.
__________________
#20 |
small engines suck
Tom's car is close to stock height in the back. It actually handles very well with that particular spring combo, and it rides far better than I'd have expected it to. Its stiffer than stock, but not objectionably so.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
grand marquis, marq, mercury, lincoln, towncar, town car, crown victoria, vic, maurader, ford, panther, box, country squire station wagon, country squire wagon, lincoln town car, 91 town car, 92 town car, 93 town car, 94 town car, 95 town car, 96 town car, 1995 town car, 1996 town car, 1997 town car, 1998 town car, 1984 town car, 1985 town car, 1988 town car 1989 town car, limo town car, 2007 crown victoria, 2008 crown victoria, crown victoria lx, crown victoria car, 1994 crown victoria, crown victoria repair, 84 crown victoria, crown victoria forum, grand marquis forum, lincoln town car forum, mercury grand marquis, 302 specs, 302 engine, 302 performance, 302 efi, 5.0 302, 302 windsor, panther, panther chassis
