GMN Chat Room    GMN's STORE!!    GMN's Gallery
Go Back   GrandMarq.NET - Panther Headquarters > Technical > Box Tech > Drivetrain/Chassis
Drivetrain/Chassis Suspension, Chassis, Drivetrain, Brakes. Everything to do with handling. Also includes transmission discussions.
Reply
Thread Tools Display Modes
Old 02-09-2010, 12:13 AM   #1
1990LTD
driving like an old man since 2001
1990LTD's Avatar
1990LTD is dead sexy, and knows it.1990LTD is dead sexy, and knows it.1990LTD is dead sexy, and knows it.1990LTD is dead sexy, and knows it.
Send a message via MSN to 1990LTD
Default signs that shocks/springs are worn?
My car is sagging a bit, more than it should, I think. Is this a case of "if you have to ask if they're bad, they're bad"? There are times when it very slightly bottoms out in the front driver side and it seems to respond to bumps/dips for too long after the fact.
I'm going with aft wagon springs/shocks and probably cop shocks/springs in the front, FWIW
__________________
- 1990 Ford LTD Crown Victoria P72 - the mothership w/ 5.0 EFI - AOD & 3.08 rear (3G swap/GMQ dash/Stern blinker mod/"mini" starter/KYB cop shocks/2.25" catless duals with Magnaflows) - Daily. soon: H.O intake/throttle body/injectors/ecu/cobra cam, rear sway bar
1990LTD is offline   Reply With Quote
Old 02-09-2010, 07:42 AM   #2
1987cp
Irish-American Dingo Whacker and Certifiable Retrogrouch
1987cp's Avatar
1987cp is almost famous1987cp is almost famous1987cp is almost famous1987cp is almost famous1987cp is almost famous1987cp is almost famous
Send a message via AIM to 1987cp Send a message via Yahoo to 1987cp
Springs: sagging.
Shocks: boinging and frequent bottoming.
If you find the overall stance and ride height to be acceptable, I'd just drop the $80ish on new shocks all around and see how you like it. Doesn't take a fancy shock to net an improvement over a set that are shot, and Gabriel's "premium" model, the Ultra, is only about US$20 a corner IIRC.
__________________
1987cp is offline   Reply With Quote
Old 02-09-2010, 05:27 PM   #3
gadget73
small engines suck
gadget73's Avatar
gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?
Send a message via AIM to gadget73
The shocks you can check with the bounce test. Push down on the corner of the car and let go. If it bounces more than once, they're probably done. Visual inspection for oil leaks is also a valid check. Springs you'd ideally have to check by measuring from the bottom of the bumper to level ground, and comparing it to the measurements in the shop manual for that. If they're original though, chances are they've sagged some.
__________________
gadget73 is offline   Reply With Quote
Old 02-09-2010, 06:49 PM   #4
GM_Guy
Stow It!
GM_Guy's Avatar
GM_Guy is on a distinguished road
Worn out springs will act like worn shocks. Especially notcable after you replace shocks and the ride doesn't improve much.
If your hitting the bumpstops, I'd say it is time for new springs.
Alex.
GM_Guy is offline   Reply With Quote
Old 02-09-2010, 06:55 PM   #5
1990LTD
1990LTD's Avatar
I don't know much about suspension, are shocks/springs ideally replaced at the same time? If I could buy new shocks now and save a few bucks for good wagon/cop springs, that would be most excellent.
__________________
Old 02-09-2010, 10:35 PM   #6
gadget73
small engines suck
gadget73's Avatar
few people replace the springs, just because it requires a decent amount of dissasembly, and frankly its kind of a pain in the ass. Shocks are a piece of cake to replace by comparison.
__________________
Old 02-10-2010, 12:39 AM   #7
1990LTD
1990LTD's Avatar
cool. I will do as suggested and replace the shocks with the KYB gr-2 whatchamacallits. If things don't improve much, I'll go for some springs
__________________
Old 02-10-2010, 05:41 PM   #8
99SLVRSTRK
NorCal Redneck
99SLVRSTRK's Avatar
99SLVRSTRK is on a distinguished road
I don't know if it's just the GrandMarquis suspension. But when taking a long corner let's say on an interchange; I have to drop speed or it feels as if I'm in a plane about to do a barrel roll. I've about had it . Gonna get some new rear springs(thats's where most of the roll comes from) maybe moog cargo springs
99SLVRSTRK is offline   Reply With Quote
Old 02-10-2010, 07:52 PM   #9
91grandmarquis
"In science it is either physics or stamp collecting." - Ernest Rutherford
91grandmarquis's Avatar
91grandmarquis is a jewel in the rough91grandmarquis is a jewel in the rough91grandmarquis is a jewel in the rough
^ that would be your vehicle saying "Easy there Burt Reynolds I ain't no Trans Am"
Try some stiffer springs and a rear sway bar.
__________________
1985 GMC 1500
91grandmarquis is offline   Reply With Quote
Old 02-10-2010, 10:46 PM   #10
1987cp
1987cp's Avatar
.... not knowing anything about the particular vehicle in question, it's also possible it was equipped with a smallish front swaybar and/or is badly in need of sway bar bushing/endlink replacement.
__________________
Old 02-18-2010, 11:03 AM   #11
Piece-it pete
Faded Glory
Piece-it pete's Avatar
Piece-it pete will become dead sexy soon
Quote:
Originally Posted by 99SLVRSTRK View Post
... Gonna get some new rear springs(thats's where most of the roll comes from) maybe moog cargo springs
The Moog cargos did wonders for body roll on the 2 or 3 I've used them on :yes:
Pete
Piece-it pete is offline   Reply With Quote
Old 02-26-2010, 04:11 PM   #12
mercman1951
Weirdo
mercman1951's Avatar
mercman1951 is on a distinguished road
You do realize that is just the way the car is, right? Even when brand new...these aren't racecars...and were never known for their superior handling characteristics around twisties without some work.
__________________
1988 Grand Marquis LS (White Lightning), 2003 Mercury Marauder,1979 Mercury Cougar XR-7
http://landyachts.homestead.com/page5.html,1951 Merc on a '88 Lincoln Town Car Chassis:http://landyachts.homestead.com/index.html
mercman1951 is offline   Reply With Quote
Old 02-27-2010, 01:07 AM   #13
cld783
I'm ridin on a dolphin, doing flips and shit
cld783's Avatar
cld783 is dead sexy, and knows it.cld783 is dead sexy, and knows it.cld783 is dead sexy, and knows it.cld783 is dead sexy, and knows it.
when you shoot sparks from underneath the oil pan..
__________________
cld783 is offline   Reply With Quote
Old 02-28-2010, 01:41 AM   #14
86GmLsCoupe
GMN Regular
86GmLsCoupe's Avatar
86GmLsCoupe is on a distinguished road
Sway bar seems to make a nice improvement in handling and I only added the smaller one on mine. In terms of springs, I'm not entirely sure of when they're due for replacement. My car has the original ones in and there is no noticeable sag. I have KYB's up front and coil over's in the rear.
__________________
1986 Grand Marquis LS 2 Door
Ext: Medium Shadow Blue Metallic, Int: Midnight Blue, 3.08 open, 235/70/15 Goodyear Aquatread III, Rebuilt AOD w/ Transgo Shift Kit, 3G upgrade from 95 5.0 Mustang, Walker Dual Exhaust w/ H pipe, Viper 5900ST alarm, De-smogged, Rear Civ. Sway Bar, and more.
86GmLsCoupe is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
www.rockauto.com Official ScottFest 09 Home!
Review grandmarq.net on alexa.com
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
grand marquis, marq, mercury, lincoln, towncar, town car, crown victoria, vic, maurader, ford, panther, box, country squire station wagon, country squire wagon, lincoln town car, 91 town car, 92 town car, 93 town car, 94 town car, 95 town car, 96 town car, 1995 town car, 1996 town car, 1997 town car, 1998 town car, 1984 town car, 1985 town car, 1988 town car 1989 town car, limo town car, 2007 crown victoria, 2008 crown victoria, crown victoria lx, crown victoria car, 1994 crown victoria, crown victoria repair, 84 crown victoria, crown victoria forum, grand marquis forum, lincoln town car forum, mercury grand marquis, 302 specs, 302 engine, 302 performance, 302 efi, 5.0 302, 302 windsor, panther, panther chassis
