| GMN Chat Room GMN's STORE!! GMN's Gallery |
| Transmissions Discussion of transmissions that will bolt to the Windsor/Cleveland engine blocks |
Thread Tools | Display Modes |
#1 |
Usual Suspect
Here's what's in my shopping cart on Summit, to be ordered Friday. PLEASE let me know if anything needs to be modified/added for the GT-40P/T5 installs.
Crane Double Roller Timing Chain w/ Iron Sprockets (is this overkill?) Equus 2.5" tachometer (going on the steering column) FRPP natural finish stainless steel shorties Summit steel throw-out bearing retainer Summit blue 8mm spark plug wires (not running enough hp to need to worry about huge wires, IMO- what's yours?) Trick Flow GT-40 1" phenolic intake manifold spacer (is this overkill?) Any modifications or additions would be welcome. What kind of oil/filter and spark plugs do you guys recommend? Most of these I find necessary- tach (for T5), throw-out bearing retainer (the stock piece on the T5 is worn and I might as well get a good one), timing chain (could I get away with stock replacement?), plug wires (mine are shot), and the spacer, for the fuel rail clearance. Again, any advice would be appreciated. |
#2 |
small engines suck
Stock HO timing chains are double roller. Might as well get something at least as good as stock. Single roller timing chains stretch more, which is generally a Bad Thing.
I have Ford Racing wires on my car. $40 for the set, they're blue, probably better quality than standard Motorcraft, and slightly cheaper. I also like Autolite plugs. I think I've got AP25 (platinum) in my e7 HO with no complaints.
__________________
86 Lincoln Town Car (Galactica). Drivetrain: 5.0 HO, Explorer cam, FMS 1.72 roller rockers, 3.55 K code rear, tow package, BHPerformance ported E7 heads, Explorer intake, 65mm throttle body, Hedman 1 5/8" headers, 2.5" dual exhaust, ASP underdrive pulley, SuperCoupe stall converter Suspension: Bridgestone Protenza G019 225/60/16 on LSC turbines, 1 3/16" wagon front bar, 1" PI rear bar, cargo coils, KYB GR-2 front shocks, F150 rear air shocks, big front brakes, ES poly front suspension bushings, 00 CVPI steering box, ES poly body mounts, rear disc brakes 91 Lincoln Mark VII LSC SE, triple black (Timewarp) - poly front bushings, KYB struts and shocks. |
#3 |
Usual Suspect
Okay. O'reilly lists a stock replacement roller chain for $13- does that sound right? Do I NEED to replace the gears or will they be okay?
I think the Summit wires will work out well. $35 for the set and I trust Summit's equipment. I'm not worried about spark plugs just yet. I have a feeling I'll end up with some Bosch +2 or something to that effect, but I'm not sure. I'll decide when the time comes... but advice is always welcome. I'm running conventional oils to break in the motor and warm up the T5 after sitting up for a while, then I'm switching to full synthetics across the board. I'm thinking Redline for the T5 and Mobil1 for the motor- opinions? Thanks, guys. |
#4 |
"Drinking your own blood is the paradigm of recycling"-Gary Busey
Motorcraft oil filters are good. Try to avoid Fram, although I have had no problems with them, have one on GL right now, no problems, but Motorcraft are better. I still need to put mine on lol
#5 |
Scott's Automotive Service
the motorsport wires are 9mm and only 5 bucks more.............stay away from those bosch +2 and +4 plugs..........an autolite or an autolite platinum for a 97-01 v8 explorer is best
i've gotten several timing sets on ebay for 27 bucks shipped.......double roller with adjustable crank spocket so you can advance/retard the cam dont forget to budget gaskets, a new water pump, belts, hoses, thermostat, need to get an egr spacer bored to 63mm, pcv screen and gromnet, vacuum hose clamps, the little crap adds up quick! good luck scott
__________________
1986 lincoln towncar signature series. 5.0 HO with thumper performance ported e7 heads, 1.7 roller rockers, warm air intake, 65mm throttle body, 1/2" intake spacer, ported intakes, 3.73 rear with trac lock, 98-02 front brake conversion, 92-97 rear disc conversion, 1" rear swaybar, 1 3/16" front swaybar, 16" wheels and tires, loud ass stereo system, badass cb, best time to date 15.94 at 87 mph. lots of mods in the works 221.8 rwhp 278 rwt 1989 crown vic gt sedan 5.0 HO 1991 lincoln mark VII bill blass (mini me) 1992 mercury grand marquis, 5.0 HO conversion finished, more to come! 1982 efm and 1986 alaska stokers keeping me warm
#6 |
small engines suck
Timing sets should always come with gears. If someplace is selling just a chain, avoid it. I bought a double roller set for my HO for like $25 at the local parts store. Its not one that I can adjust the cam advance on though. Check out the replacement avaliable for $13, it won't cost you anything to look. You're looking for one that has gears with a double tooth. Single roller chains have a gear with a single wide tooth that goes all the way across. Double roller chains have two narrow teeth on the outer edge of the gear. Single rollers are a little cheaper, but they stretch more.
I'm also tending to agree with avoiding Bosch plugs. Only thing I ever had them run worth a damn in was my VW, and they were OEM. The plats ran like crap in it tho, had to run the copper core plugs.
__________________
#7 |
Ford Fanatic
AutoZone carries the Dynagear dbl roller set for less than $25. I have run Dynagear on my Clevelands, 429 and 302's with no problems.
#8 | |
Usual Suspect
Quote:
I've budgeted for new gaskets, but my water pump only has about 5,000 miles on it, so I'm going to reuse it. I also have new hoses. I'll replace thermostat and belts, PCV, etc. New vacuum system has about 2,000 miles on it. Why do I need to get a 63mm EGR spacer? One doesn't come on the Explorer motor? What I'm getting is from throttle body to oil pan... Again, thanks! |
#9 | |
Ford Fanatic
Quote:
#10 |
Usual Suspect
Okay- so, what EGR spacers can I use?
Also, what about this for timing: http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW[/url] |
#11 |
you also need to replace the explorer oil pan and oil pump pickup
__________________
#12 |
I would not run the Phenolic spacer. At least on a regular HO, they don't make power on the dyno.
I run the dynagear timing chain and sprockets. Under $20 at auto-zone. How much for a parts store throw-out bearing? If you run lifetime warranty parts store ignition wires, you can return them if they ever break or burn. Something to consider. I run the black Ford Racing wires and they seem to be fine. Good luck. Are you going to run the HO camshaft? Tom |
#13 |
Usual Suspect
Lincoln- I will be swapping the oil pan and pick-up from my CV motor.
TommyN- I want to run the phenolic spacer to get the clearance for my aluminum valve covers and the fuel rails, so I don't need to do any grinding or cutting on the GT-40 intakes. It's not to pretend I have more horsepower- just to get the clearance. I'll check into the Dynagear equipment. I got a new throw-out bearing with my FRPP King Cobra clutch kit, but I need a new bearing retainer (the original is loose). $30 was the best price I found on a stock replacement, so I'm gonna go with Summit's steel retainer for $40. I forgot to check on the wires today- we've been unbelievably slammed at work, still catching up hundreds of files from Katrina and Rita. I'll be running the HO cam, yes. Fairmont_Kevin said he has an ECM for me... have you shipped it, Kevin? |
#14 |
He who shall not be mentioned.
Try and find a 93-95 Lighting EGR spacer, or you will have to do some rigging. I saw some aussie HO spacers on ebay that look the same as the vic ones but were 60mm, which is a bit small but they could be ported a bit.
__________________
former builder/owner of badass panthers. |
#15 |
Usual Suspect
FRPP 68mm EGR spacer for $30 plus shipping. I missed the bid, but I'm in negotiations with the seller to re-list and I'll buy it immediately.
I'm also ordering a main girdle and billet steel flywheel- both on a major sale right now, $200 for both. I want to go ahead with the girdle so that I won't need to worry about block troubles as I upgrade. Having a 5-speed on a 4,000lb car with the horse I'm hoping to end up running can be Hell on that block. Plus, I figure- it's a great deal, so why not go ahead and get it? Do any of you know about the valley supports? I'm told I can do those with the engine still in the car, but I don't know. I don't want that block to have any chance of splitting. I think that's all my updating for now...
__________________
2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets. 1992 Explorer Eddie Bauer, slight lift, 34s, and A/C... 1990 Crown Victoria, '10 Mustang 18s, '04 intake, 3G, 925/225 springs... |
#16 |
It'll still split. You need to be running some serious HP though, 400+...And I haven't heard anything about galley supports...main supports yes..
The EGR doesn't have the bosses for the studs to mount the throttle bracketly to...
__________________
#17 |
Usual Suspect
I'm drunk, so I can't really understand what you just said. Can you say in in "chemically imbalanced" terms?
__________________
#18 |
Usual Suspect
I went down to the wrecker today to get my motor. It's a 2hr drive there! The guy was telling me he couldn't believe the salesman offered to sell it to me for $650 (and even said the guy may not be employed, come Monday...) because it only has 100,000 miles on it and they had 1145 written on the motor in five spots, meaning they were seriously asking $1145 for it! He said they had to honor the man's word, so they were going to deal for that price... Anyway, I wrote out the check, then barely caught myself.
"Would you be offended if I tell you I want to see the motor before I give you this check?" "No, come on!" We walked to the back and there it was. I searched for the "GTP" on the head and it was there! I was so excited. I handed him the check as my buddy Matt drove his truck around the back to have the motor dropped into the bed of his F-150 (the brand new ones are AWESOME, by the way!). Problem is, my check didn't clear because Telecheck couldn't get into my bank account (Hancock Bank is having system problems). I called my boss (we work for Hancock) to see if she had any ideas of what to do, but she was on the road and had left her cell phone in the office. So, I was screwed. We left and stopped at a gas station to get some snacks and directions. On the way out, my boss called me to ask what was going on. I told her the situation and asked if she had any ideas. She didn't. Officially screwed. I figured I'd have to get the cash directly out of my bank account, drive WAY out into nowhere again, and find out that they won't deal at $650 any more- they want full price. "Well... do you think they'd take my credit card number over the phone?" That's my boss saying that! "Turn around and call me when you get to the guy. I'll give him my credit card and you can pay me back later." How awesome is that?! So now, I have a GT-40P sitting in my garage. Here's what they included: Engine (long block) Intakes Throttle body/ the weird elbow thing Entire engine wiring harness Fuel rails Fuel injectors Basically, if I could figure out where those wires go, I could run it with an Explorer computer and keep the coil packs. So... I think I'm going to do some research. I want to say MSD makes an ignition box for coil-pack equipped V8s. All I'd need is a MAF sensor and a MAF computer. I'm thinking about it. We'll see. Just looked up the MSD box. It's MSD part #62112, a box designed specifically for distributorless ignition systems. Not cheap at all, but I'm thinking it's worth it if it would allow me to keep the coil packs. Opinions?
__________________
#19 | |
You like your teeth?
I think it would be interesting. VERY interesting...
__________________
1979 F100 Custom SWB 300/3 speed. Base model GOODNESS!! 2009 Grand Marquis LS "GMGT III" 2005 Bullitts, Powerslot Rotors/Hawk HPS Pads 1987 Crown Victoria 2dr "Project79" 15.283 @ 90.48 Quote:
#20 |
Driver
Sweet deal/steal!!! How far are you from New Orleans, LA? If you find the right person, can you get a "storm car" 5.0L Explorer/Mountaineer for pennies on the dollar? Their called "storm cars" up here if they were under water, stuck in the snow or damaged some other way. Tons of parts are going to coming out of the areas Katrina hit very soon. I was thinking about driving down with a flatbed truck and a pocket full on money. You could be my parts supplier down there if you're interested.
__________________
![]() '90 Mercury Grand Marquis GS Baseline numbers totally stock, 123 rwhp, 239 rwtq Motor died 12/30/06 and I'm looking for a shop to do my motor swap. ![]() '95 Ford Bronco Eddie Bauer 4x4 5.0L Ford V8 with Mass Air Daily driver when I'm not riding the KZ. '82 Kawasaki KZ440 ![]() My first bike, but I want more power. R.I.P. Jason Harrill 6-12-06 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
grand marquis, marq, mercury, lincoln, towncar, town car, crown victoria, vic, maurader, ford, panther, box, country squire station wagon, country squire wagon, lincoln town car, 91 town car, 92 town car, 93 town car, 94 town car, 95 town car, 96 town car, 1995 town car, 1996 town car, 1997 town car, 1998 town car, 1984 town car, 1985 town car, 1988 town car 1989 town car, limo town car, 2007 crown victoria, 2008 crown victoria, crown victoria lx, crown victoria car, 1994 crown victoria, crown victoria repair, 84 crown victoria, crown victoria forum, grand marquis forum, lincoln town car forum, mercury grand marquis, 302 specs, 302 engine, 302 performance, 302 efi, 5.0 302, 302 windsor, panther, panther chassis
