Car rumbles at idle. When revving and letting it down to idle, it drops down low and then back up. Then it shakes about 15 seconds. I don't know if this video helps but maybe you guys will hear something I won't.
Vicky Misses
Funny I'm kind of having the same problem it does it on first start up
Originally posted by gabegt90it could be arching
Sounds like its running pretty much normal to me. Might need a tuneup but I can't hear anything wierd. Hard to tell tho with a camera mic.86 Lincoln Town Car (Galactica).
Yeah that's the weird thing. It runs normal did I mention when I start it up it runs high and then really low to the point of stalling and then it goes back up to normal and it stays there. It vibrates. At the end of the video you should hear the idle going down more and then back up. It might need a tune up. It only shakes at idle or going down to idle and when I first start it up.
mine used to stall because of the idle air control solinoid but My car could use new plugs and wires though
If I unplug that, it stalls out. If I keep it in there it stays running. It might be going. We're talking about the actual motor that controls it right? I am putting up another video about the start up problem.
Do a tune up, plugs, cap, rotor, wires, fuel filter. Run some injector cleaner through it. Also, some seafoam could help. Could just be all the shit builtup on the valves absorbing the fuel before it gets into the cylinder. Need to cover the basics first and get it tuned up.Builder/Owner of Badass Panther Wagons
This is the new video of the car's idling thing. I just started it up ran to the front and started recording. After the plane goes by, you should hear the idle go down way low and then up. I am going to give it a tune up. Would giving her a tuneup rid me of this problem? I am going to give her one anyway, but I was just wondering.
