Misadjusted tv cables can cause problems with shift timing and quality and can lead to expensive trans repairs. This link is to very good instructions on how to adjust your tv cable. I performed the work described and it has made a huge improvement, and resolved my pinging problems because i'm no longer lugging gears due to ultra early shifts.
http://www.txchange.com/aodadj.htm
Check it out. Now would also be a good time to replace your 2.00 tv grommet on the throttle body butterfly lever (it's the black one opposite the throttle cable post). When these fail it can lead to your aod going down the toilet.
