GMN Chat Room    GMN's STORE!!    GMN's Gallery
Go Back   GrandMarq.NET - Panther Headquarters > Technical > GMN Reader's Rides
GMN Reader's Rides Post pics of your car in here, works in progress, etc... Ford/Lincoln/Mercury vehicles only.
Reply
Thread Tools Display Modes
Old 06-11-2007, 01:23 AM   #61
gadget73
small engines suck
gadget73's Avatar
gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?gadget73 is unbelievable. Superstar?
Send a message via AIM to gadget73
Quote:
Originally Posted by MeLikeyStripperChicks View Post
Thain, that air filter, why the heck did you stick it there?
Because thats where the free parts I found located it. I got tired of hearing noise about the lack of filter system, and the stock air box flops around annoyingly when you have no bracket to locate it. Its also ugly as hell.
I could get away with that cause I got open hood and the hot air from the manifolds actually gets pushed back down and under the car, but yers just gets trapped up there and sucked in my the engine - why not extend the piping and pint the filter behind the washer bottle?
Because I'm lazy and I don't want to re-locate or remove my washer or overflow bottles. I kind of like the stock ones, and moving the filter to a better spot would require doing something with them. I'm also planning on making changes to the intake soonish anyway, so I might end up having to relocate the stuff anyway.
Also what elbow and silicone fitting did you use for that filter?
I believe it came from the Box of Mike, but don't quote me on that. Unknown what they're from, it was stuff sitting around the shop.
__________________
gadget73 is offline   Reply With Quote
Old 06-11-2007, 01:31 AM   #62
gadget73
small engines suck
gadget73's Avatar
Quote:
Originally Posted by OVERKILL View Post
In regards to your heat issue, what was going on? Fitting a cooler thermostat is only helpful if your cooling system is adequate enough to handle it, as the cooler you try to run things, the more cooling is required to do that. Perhaps your other T-stat was dying and sticking shut? Because if it can stay at 185 now, then obviously your cooling system (cooling capacity-wise) wasn't the issue.....
Yes, the Mark VIII fan doesn't cover the entire rad, but it's pretty close! It covers a lot more than any of the other fans I've seen........
Temperature on the stock gauge was running over at the L, sometimes slightly past it edging into the H area, add-on gauge put me at 205-215 cruising on the highway with no AC. Probably the thermostat was just shot and replacing it with a new of the same temperature range would have fixed it. I had a brand new 180 in the trunk already though, so I used it. The 195 was a newer Motorcraft, I'm not certain if I installed it with the Explorer intake, but it was not more than a year old. It always ran on the hot side of the scale on the stock gauge, and I'm not entirely sure I trust the add-on one since the temperature probe looks like it may have suffered a little damage at some point in it's life. Not sure which is more trustworthy at this point, but they now both read happy, stock gauge dead center of the scale, add-on at 185-190. I don't honestly recall but its possible it was the thermostat in the motor when it overheated badly last year from a failed water pump gasket. I might have cooked it then and it didn't get really apparent till it got hot outside.
__________________
Old 06-11-2007, 03:35 AM   #63
Archangel
Guest
Posts: n/a
Quote:
Who said anything about relocating bottles? Did I relocate my bottles?
Old 06-11-2007, 03:40 AM   #64
Lincolnmania
Scott's Automotive Service
Lincolnmania's Avatar
Lincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expertLincolnmania is a panther expert
Send a message via ICQ to Lincolnmania Send a message via AIM to Lincolnmania Send a message via Yahoo to Lincolnmania
yes the warm air intake came from the box of mike
__________________
Lincolnmania is offline   Reply With Quote
Old 06-11-2007, 01:41 PM   #65
Mr. Land Yacht
from 5.slow to 5.Oh YEA!
Mr. Land Yacht's Avatar
Mr. Land Yacht will become dead sexy soon
Send a message via AIM to Mr. Land Yacht Send a message via MSN to Mr. Land Yacht
ooh..nice motor dude! me likey!
what is that intake? the explorer intake?
__________________
'88 Mercury Grand Marquis LS-current 1/4mi time 15.37@93mph at Lapeer
http://www.cardomain.com/ride/411357/1 http://www.supermotors.net/vehicles/registry/11285
Mr. Land Yacht is offline   Reply With Quote
Old 06-11-2007, 01:48 PM   #66
zwack88
Loves his old junk
zwack88's Avatar
zwack88 needs the rep
Damn that looks great man. Usually I don't like the light ford blue in cars this new but in yours it looks great! You running it down the track at SF?
__________________
1999 Eclipse GS-T, 1984 Firbird, 1988 Comanche
zwack88 is offline   Reply With Quote
Old 06-11-2007, 09:21 PM   #67
gadget73
small engines suck
gadget73's Avatar
Yes. early 97 Explorer intake with internal EGR, a Lightning EGR spacer, and the 65mm Explorer throttle body.
Quote:
Plan on it. I kinda like the lighter color because its easier to see leaks. The dark blue hides a lot which is good or bad depending.
__________________
Old 06-11-2007, 09:28 PM   #68
OVERKILL
OVERKILL's Avatar
OVERKILL is on a distinguished road
Well at least with the 180 you get SLIGHTLY more timing The ECM starts pulling timing just past 190 degrees........
__________________
1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
OVERKILL is offline   Reply With Quote
Old 06-12-2007, 08:45 AM   #69
torquelover
Where's the torque?
torquelover's Avatar
torquelover has some kind of aura thing, or something.torquelover has some kind of aura thing, or something.
How do you like the new steering box? Still using the stock P/S pump?
__________________
Indefinitely torqueless in suburbia...
http://www.supermotors.net/users/torquelover
torquelover is offline   Reply With Quote
Old 06-12-2007, 10:33 PM   #70
gadget73
small engines suck
gadget73's Avatar
Quote:
Love it. Nice and firm. The car has slightly too much caster so the wheel is a little heavier than it needs to be. Think next time I have it aligned its going back to factory specs. Right now its at like 6 degrees, factory is 3 degrees. The extra stiff torsion bar in the box makes me need that extra caster a whole lot less. And yes, factory (original too I think) pump works fine with it. Lines are coupled because the fittings on the box are different but thats it.
__________________
Old 03-29-2009, 01:44 PM   #71
87gtVIC
The Box..Think Inside It
87gtVIC's Avatar
87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?87gtVIC is unbelievable. Superstar?
Really nice car, i love everything you have done to it. Do you have any updates?
__________________
~David
1987 Crown Vic.
Mods: Mustang Headers into Mustang H-PIPE, B&M Shift Improver Kit, High Output Upper Stuff, 1/2" Intake Spacer, Mustang Valve Covers, Bumped Timing, 2009 Police Zip Tube and Air Box, K&N Air Filter, 3G Alternator, Under-Hood Fuse Box, Headlight Relays, Police Rear Sway Bar and Wagon Front Sway Bar.....and much much more. All around fun car to drive.
BOX PARTS FOR SALE CLICK ME: NOS 1979 D.Side Clear lens, police gauges, electrical stuffs etc.... lets make a deal. Make some offers.
LTB BOX PARTS : Chrome Pedals, Transmission Cooler, seat belt sleeves, 90/91 Relay housing/cover...Please Contact me
87gtVIC is offline   Reply With Quote
Old 03-29-2009, 10:59 PM   #72
gadget73
small engines suck
gadget73's Avatar
I think I've replaced the body mounts and tires since the last update. Might have swapped back to stock springs, but I don't know the timing exactly. Its got a 3 row radiator now too, a new stereo and a much nicer sub install. I don't document much. I just do stuff and drive the car. I have limited time to do major work on the car, so I just don't bother with taking pictures.
__________________
Old 03-30-2009, 05:15 AM   #73
87gtVIC
87gtVIC's Avatar
So i guess a new top is still in the making.
__________________
~David
1987 Crown Vic.
Old 03-31-2009, 12:39 AM   #74
p71towny
Cult of Personality
p71towny's Avatar
p71towny is dead sexy, and knows it.p71towny is dead sexy, and knows it.p71towny is dead sexy, and knows it.p71towny is dead sexy, and knows it.
All's I know is Im happy the aquarium tubing is gone lol.
__________________
p71towny is offline   Reply With Quote
Old 08-15-2009, 10:11 PM   #75
gadget73
small engines suck
gadget73's Avatar
Since I never update shit, here's some new engine pics. Mass air was done a couple weeks ago, along with the inner fender swap and the airbox setup. Inner fender, overflow bottle, and vac reservoir/relay cover is 1990 Towncar, airbox 1994 Towncar, air tube is 98ish Vic. The relays aren't re-wired into the correct 1990 relay panel, its just my stock relays shoved in the cover. Mass air meter housing is 94 Townie, but the electronics are 95 Tbird with a V8. ECM is a Mustang A9M. I've noticed better fuel economy, better power, and better drivability since doing this. Haven't put it on the dyno, but I've had it at the track and gotten a best of 16.021 in the quarter. Considering I used to be in the 17s, its doing much better now.
Oh, if I've never mentioned it before, the valve covers are 1985 Mustang with my own paintwork. Masking those off was a real pain in the ass too, let me tell you.
ID:	18794   Click image for larger version
ID:	18795   Click image for larger version
ID:	18796   Click image for larger version
__________________
Old 08-15-2009, 10:22 PM   #76
torquelover
Where's the torque?
Looks real good.
__________________
Old 08-15-2009, 10:45 PM   #77
p71towny
Cult of Personality
p71towny's Avatar
WOW. That's really nice mang! She's come a long way. Once its repainted it'll be a new car.
__________________
Old 08-15-2009, 11:13 PM   #78
OVERKILL
OVERKILL's Avatar
Looks awesome!
__________________
Old 08-16-2009, 05:08 AM   #79
87gtVIC
87gtVIC's Avatar
Very nice.
__________________
~David
1987 Crown Vic.
Old 08-16-2009, 06:12 AM   #80
Lincolnmania
thains car is awesome!
__________________
Reply
Tags
good work!
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
www.rockauto.com Official ScottFest 09 Home!
Review grandmarq.net on alexa.com
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
grand marquis, marq, mercury, lincoln, towncar, town car, crown victoria, vic, maurader, ford, panther, box, country squire station wagon, country squire wagon, lincoln town car, 91 town car, 92 town car, 93 town car, 94 town car, 95 town car, 96 town car, 1995 town car, 1996 town car, 1997 town car, 1998 town car, 1984 town car, 1985 town car, 1988 town car 1989 town car, limo town car, 2007 crown victoria, 2008 crown victoria, crown victoria lx, crown victoria car, 1994 crown victoria, crown victoria repair, 84 crown victoria, crown victoria forum, grand marquis forum, lincoln town car forum, mercury grand marquis, 302 specs, 302 engine, 302 performance, 302 efi, 5.0 302, 302 windsor, panther, panther chassis
