The IAC valve is usually the root of cold start problems, and idling problems. Either the car starts then wont idle, or it wont start without foot on the throttle. But car runs fine with foot on the gas. These are 2 classic symptoms of IAC failure. May not set a code. basically this thing controls the air with the throttle closed allowing the engine to get the right airflow to idle. Most failures are when the weather is cold. But not always. Here is what it looks like.
96+ is a 15 minute job, the 92-95 well maybe an hour if you are in-experienced. The cost is usually 50-70 bucks for the part. Lots of people find sucess with Napa for this part, but any identical one should be great.
