HELP
Guest repliedI would use a thin coat of RTV on the threads instead of teflon pipe tape ....
I would use Permatex thread sealant or equivalent. The tape tears too easily.
There's also an Oil Filter Adaptor sticky here...in case the leak is dripping from there, but actually coming from somewhere else. Hairline cracks can be hard to see, and that part is under pressure so even a small crack will cause you to lose oil at an alrming rate.
Good Luck and
Good Day
Leave a comment:
Originally posted by Blaze86VicPut some pipe tape on the screw, that should seal it up good.
Leave a comment:
Guest repliedgot a pic? sounds like the oil filter plate-adaptor for the oil lines?
Leave a comment:
HELP
I think I have a oil leak starting on my gm.. Its coming from a large golden screw on the oil pump on the bottom. The parts right next to the filter....I dont know what to do except replace the pump...Any help would be appreciatedTags: None
Leave a comment:
